Soooo, It's running ,, but at idle with IAC at about 7-10, every 30 seconds or so, it drops down to about 400 rpm and the IAC opens to allow air in to recover to 12 to 1300 rpm before it settles back down, and so on and so on.
Seems like a vacuum leak to me, and probably a PCV valve that is hanging open most times, and then slowly shuts down, cutting off that extra air and driving the rpm down until the IAC allows air back in.
Am I on the right track ? I will take the PCV valve out of the equation later for the next test.
Hard to say. What's your afr do when that happens? Using timing control? What's the advance do when the rpm drops? How high does the iac go?
What's your initial timing at the moment? Is it verified with a timing light?
Mayne data log the idle and post some numbers or a screen capture of the data.
It could very well be a misfire or the timing is moving to try and hold idle and its not helping. Could be too lean or rich of an afr. Could be the learn value moving too fast, or the afr jumping too much at a time.
This was exactly what I had and reducing the idle learn and loop rate helped a bunch. As did making the afr jumps smaller.
@ken5124 Exactly what I had: no load idle would randomly drop but recover. It's good to eliminate any possible vac leaks, but that may not be it.
Go into 'afr closed loop' then scroll down to idle fuel learn rate. Turn this down to 2-3.
Then scroll up to 'idle trim jump' both pos and neg. Write down what they are, then try setting them at 10~15. Write down your AFR loop speed, and then cut it in half. Remember to 'send' each change after you edit the value by pushing the button. Then go to 'idle trim rate' and write them down too - but then lower them to about half the default. The POS value should be higher than the neg by 10-30% (based on my playing).
Then go to idle control. Look at the Loop rate up/down. Lower your 'down' setting to very low. 1/2 to 1/4 the default value.
Doing all this should have immediate effect on your idle quality. I did this while idling in the garage. It went from a choppy 600~1100 idle that sounded like it wanted to die on the low end, to a solid 850 and varies by less than +-75.
You and i had a phone conversation as you were working on your buddies car correct? If anyone needs a new, pace purchased, pro billet distributor pre locked I will do it for $50. tsp or msd. If that helps anyone else out.Just installed a FiTEch EFI on a Magnum 360 in a 67 Dodge Dart.
Very happy with the results! It took a lot of tinkering on my part since we are re-wiring the whole car and changing a lot of items. Wasted a lot of time not purchasing the MSD Pro-Billet from the beginning, and not installing a jumper wire from IGN1 to IGN2 to by-pass all the ballast BS. Since we are working with a painless kit and the original switch it tripped us up for quite a while.
Suggested to Pace Performance to put together a kit with the Street 600hp, FCC, and Lockout Dizzy ready to go. I would have sold them 2 more kits last week if they want to put that together (all Chevy guys at work).
Very poor documentation on the Timing control, I have worked with the FAST and Megasquirt items in the past but they need to clean that up. I still don't comprehend why they need the phasable rotor, and talking to Tech Support they describe a completely different way to install it.
We have a lot more tuning to go on the car, but installing new gauges and finishing the wiring before we drive it (slowly) so it can learn and then I will start messing with the tunable options.
Hi Johnny- What distributors are you recommending for the FiTechs? Can you provide some URLs? Thanks!You and i had a phone conversation as you were working on your buddies car correct? If anyone needs a new, pace purchased, pro billet distributor pre locked I will do it for $50. tsp or msd. If that helps anyone else out.
There are several videos out on the rotor phasing and what it does. Essentially your are verifying that crank TDC is in fact matched to the distributors shaft/terminal pole position. Engines are VERY commonly 2-6 degrees off.
So...at low load cruise, the fitech throws a load of timing at the engine for economy. If its off another 6 degrees, you are on the verge of spark jump, or detonating. If that helps the reasoning
Check out Johnny's post on this thread #795.Hi Johnny- What distributors are you recommending for the FiTechs? Can you provide some URLs? Thanks!
Excellent. Thank you sir!Check out Johnny's post on this thread #795.
Sure,Hi Johnny- What distributors are you recommending for the FiTechs? Can you provide some URLs? Thanks!
Hi 340Duster247,I know it's been asked before, but I didn't read a strait answer and want to double check with my set up. I'm going to run timing control, and wiring the system with my MSD box. My question is where are all you guys running your white acc. wire. I just want to make sure I'm getting the Acc. Power when cranking.
Hi 340Duster247,
I believe if you want to use the FiTech timing control, then you can't use the MSD box. You can use the MSD but, but timing will need to be handled by the distributor.
Travis
That's what I did. Now I need to take on the rotor phasing. Before my engine was locked out at 34. Didn't mind it at all. Ran best there.
If I follow fitechs instructions. Can I set my base timing at 20 or 25 and go from there?
My first time phasing a rotor....
