FiTech EFI system
I'm just curious about the VR advance If my timing at 4000 is off by 2° Do I add 2° to the factory 17.5 to make it 19.5 or do I erase the 17.5 and just put 2 in the handheld.
Interesting find on the Chevelle forum regarding Fitech PCV Vacuum port. Seems the PCV port only feeds one side of a divided plenum dual plane manifold. The Crankcase fed PCV vapor would then only impact some cylinders?
FITECH EFI TUNING tips, info sharing, ideas, settings, etc... - Page 92 - Chevelle Tech
Post 1368
What are your thoughts? I think I will pull pcv vacuum from both the 3/8 vacuum ports, so that vapours feed both sides of the intake?
Ken
Post 1368
Ken[/QUOTE
I read that. I was thinking if cutting the divider down would help?
Cutting the divider might help, not really sure, but I am not going to pull the intake to do that..
I have a couple of emails out..
one to Fitech's owner to advise if the 2 3/8 vacuum ports each pull vacuum from opposite sides of the throttle body, If so, I should be able to hook them together ?( this doesnt help those with Power Brakes mind you)
and the second to the Wagner Dual flow PCV valve inventors.. I suspect they will know far more about this than I do. and they should be able to advise if connecting both ports would be of benefit.
Well.. that's customer service... Gene Wagner called me back while he is at SEMA, to discuss this concern with me.. That's pretty good.
He strongly suggests that the PCV valve system should equally distribute crankcase vapors to the entire motor. Seemed to think that Using both 3/8 vacuum ports at the same time would be beneficial. So that will be the plan.. soon as my Dual Flow valve gets here next week.
And much to my surprise (haha) no response from Fitech.
Hi Ken5124,
I wonder if a small spacer under the FiTech would be enough to allow pvc to work for both sides. Something like this.
Edelbrock Carburetor Adapters 2732
https://www.summitracing.com/parts/edl-2732
It is pretty thin, so shouldn't cause under hood space issues, but would provide a gap above the divider in the intake. Thoughts?
Travis
problem is I already use a four hole spacer. for fitment issues.. Which probably worsens my situation.
If using both fitech vacuum ports don't work I will drill into the spacer on both sides and then use them both
Hey Ken, I have snooze a bit on this thread but reading through your last Few posts. Does your center divider have an "equalization port" in the divider? Or completely separate dual planes? Or am I misreading entierly?lol Just curious. Your goal is to not only pull vac reference from one bank?
Hi my intake is a mopar dual plane .divided in the center. I do not think there is an equalization port.
I want the controlled leak of the pcv to bring crankcase vapors to both sides of the intake. if the FiTech throttle body pulls from 1 bore only as indicated in another members post, then I would think the air fuel ratio would be different from 4 cylinders to the other set. ??
Gotcha! My initial thought would be to lower the center divider slightly. There have been numerous articles written over the years showing it adds a little bit of power. And equalizes the two sides. Or..I see the skinny edelbrock plate posted above which would effectively do the same thing. That would be the easiest way to make sure you weren't only pulling from one bank.
Maybe you could just replace your existing spacer with one that has a pvc port built in. A google search shows a wide selection in the $29-$36 range.
Travis
Yes, a new spacer is an option for sure.. Will first try hooking the 2 fitech ports together, then may adapt my existing 4 hole if I need too. One way or the other I will feed both sides of the intake with the PCV line .
Fortunately, Winter is slow to arrive in Winnipeg this fall, so There's still time to fiddle and test drive before snow arrives.
And still no email back from Fitech..
Ken
Hey just want to let everyone know that there's a "fitech owners group"started on facebook. Lots of knowledgeable people on there just helping each other out.
Even Cody (fitechs technician) has joined the group from his personal facebook to answer any questions we might have.
I know lots of guys have a tough time getting a response from fitech. With Cody being part of the group we are getting answers right away. Even people with warrenty concerns are getting The help they need, and taken care of.
The more people we have the better.
gotta link??
I don't know how to link facebook pages since I use my smart phone and it doesn't show an address.
Here's a pic of the page. If you pm me your facebook name I'll invite you too the page/group.
Well worth it.
Spoke to support. My unit is going back for an RMA. Disappointed but at least the support is very good.
So, updating my post with a little rant. I sent the unit back. It was received by Fitech on Nov 8th. Cody told me on the phone that they usually process RMAs in 3-4 days. Ok, it's been a little more than 3-4 days and even at this point I would still accept if the unit was to arrive at the end of the month, but communication from these people is terrible. I've sent emails, tried calling, left voicemails, even sent a PM through their Facebook page and no response. I understand that they are busy and are maybe back ordered. That's a wonderful problem to have, especially for a new business but they need to staff up. And the very last thing they should be doing is letting all of their dirty laundry air on Facebook and allowing social media to be their support forum. That is a terrible business/customer service model. They need to step up their game on customer documentation, a knowledge base and maybe their own (and moderated) support forum. //rant off
Quick update. Just got off the phone with JEGS, where I bought the unit. JEGS customer support validated my own observations. "FITECH support is terrible", they said. JEGS doesn't have a lot of recourse since I sent the unit back to the mfr, but the lady was nice enough to fire off an email to FITECH with the hopes that a JEGS email would have more weight than mine. Guess what? I immediately got a response through the Facebook IM. FITECH claims they were "waiting on an ecu which they are receiving tomorrow" and will be sending back my unit tomorrow or the day after.
Here is my take on this. For those of us that have bought these units, we are "early adopters". The company is going through growing pains, as well as design or quality issues and are probably processing a ton of RMAs, as they sort out their design, assembly, parts supplies or in-house QC issues. I know how it goes. I owned a hardware company and designed and manufactured industrial spec embedded systems for 10 years. It's hard to get your product 100% the first time and inevitably you end up cycling a lot of product out of the field and back to your lab for re-work or replacement, the latter being the least desirable due to cost....So, my feeling is, if you are fine being an "early adopter" and going through the growing pains along with a start-up company, then FITECH is right for you. The product has a lot of promise and you might luck out and get a good unit. If this is for your daily driver and not a weekend warrior vehicle like mine, I would maybe wait till they get settled and are shipping more consistently reliable product. I'm still hopeful mine will work out and will gladly report back here with my results. After all, it did run good, the few brief times I drove it and I would love to see FITECH succeed.
Yah that's weird some are having a hard time getting a response from fitech. They said they would contact me the following work days. I didn't hear anything the morning of, so I reminded them with a quick email and sure enough I got a phone call right away. Also got a email telling me there would be a call.
