Frank Mopar
There is Fitech Pro Cal software available. Like everything FiTech, you have to dig for it.
Just bought a used system. Attempted to connect the USB port to computer, and got a timeout error. Is there anything about that hookup that is different than simply popping the memory card into the computer directly?
What kind of memory card are you refering to?
The Fitech handheld is what I think you are trying to hook the laptop to download data? The handheld just needs to plug into the usb with a cable. No 12v supply is needed. It picks power from the usb. If we are still not on the same page I apologize
My car is in hibernation. Tomorrow Ill go hunt up my handheld and see what happens when i plug it into my laptop. I used it only on my desktop and it was a matter of just plugging it in.
Does the screen light up at all for you when plugged in? Or can you charge a cell phone through the usb on the laptop (if you have one)?
Funny you say that. I had a knock off dizzy in my car and I upgraded to msd. Now my tach jumps up and down randomly. I did the twisted wire, separated the wires to the box added the grounded shield wire and still not fixed.Also make sure you twist the wires coming from your distributor to the throttle body and as an added measure slide braided steel mesh over it and ground the one end of the mesh.
Yes they both work the same way. I thought that the noise was coming in on the tach wire but then after all of the shielding and wire twisting I still had a RPM Nose Fault. I then (because of my electronics background) figured that it must be coming in on 12 volt supply wire so I made that filter. The problem hasn't returned. It's easy to make.
Calls to msd results in someone talking down to you. No help whatsoever. Ok Msd expert tell me why the knock off works fine. No answer.
just wondering if the fitech is seeing that same tach signal
Yes they work in the same manner. They both use a magnetic pickup distributor to trigger the ignition timing. After several attempts at shielding and twisting the wires with no success I decided (because of my electronics background that the noise must be coming in on the 12 volt supply line. So I made the filter, it's easy to make with the total cost being only a few dollars.Funny you say that. I had a knock off dizzy in my car and I upgraded to msd. Now my tach jumps up and down randomly. I did the twisted wire, separated the wires to the box added the grounded shield wire and still not fixed.
I agree on the resistor plugs any radiation of EMI can cause issues with the throttle body trigger signal. My filter is for any noise that might be coming in on the 12 volt supply line (from the alternator brushes etc). It helped eliminate the noise issues with my FitFiT.What type of filter?
As I read and learn more about computer controlled systems I see that resistor plugs should be used in these applications. Ill be switching to resistor plugs.
Ah I see, well then it's definitely EMI. I would try the resistor plugs and in addition shield all of the wires going into the throttle body. Make sure that you ground the shielding.Race car with no alternator here so I can rule that out
2-Step Control Spark Cut Feature
Just installed this new update on my 1200PA. There is absolutely no Fitech documentation on how this works. But basically you install the new firmware (T198i) on the ECU, new software on the handheld. Wire a 12v switch/button to the AC lead on the 4 pin extra connector that comes on the Power Adder models to trigger the spark cut. I've only briefly tested it with a temp switch and it seems to work, cutting spark and keeping the RPM down.
View attachment 1715154208 View attachment 1715154210
Nice feature, I have a 600 PA and as far as I know that 2 step feature isn't there. I am not using a supercharger this time around so I just removed the plug from the throttle body in preparation for my new NA 418 stroker. By the way did yours start right up? Did you get any "RPM Noise errors?2-Step Control Spark Cut Feature
You may need the latest update for your particular model. I gather there isn't a universal firmware, but rather specific to your model.Nice feature, I have a 600 PA and as far as I know that 2 step feature isn't there. I am not using a supercharger this time around so I just removed the plug from the throttle body in preparation for my new NA 418 stroker. By the way did yours start right up? Did you get any "RPM Noise errors?
