fuel filler problems
Early A-Body Discussions
  1. wheelsport
    wheelsport Well-Known Member
    90
    47
    Jan 21, 2019
    Vancouver, Washington
    Local Time:
    12:01 PM
    I have had problems with refilling my car forever. Gas will burp out all over while refueling. I know I'm not the only one with this problem. I've tried going very slow which isn't really working like it should. While refilling slowly, fuel comes out of the vent tube. I was just told not come back to the gas station until I fixed the problem. Some of you guys have modified the filler neck. I have an idea that might work to stop the fuel from coming out of the vent tube. The fuel gauge sender on my car has a vent line that I have plugged. Will connecting the vent tube to the vent on the sender solve the problem?
  2. H22A4
    H22A4 Does anyone read this?
    2,124
    1041
    Aug 4, 2006
    YVR
    Local Time:
    12:01 PM
    While I don’t have an early a body, the slope of the filler neck in my Scamp also has the gas burping out as it’s almost full. I just ease up on the trigger and place my ear close to the nozzle and listen for when the tank is almost full. I glance at the gauge when stepping out of the car to give me an idea how much it’s going to take to fill and then start easing up on the trigger when I’m near that.
    I’m sure some folks at the station think I have a sniffing problem.
    • Agree Agree x 2
    • 64conv65hard
      64conv65hard FABO Gold Member FABO Gold Member
      783
      302
      Jan 16, 2009
      germantown md
      Local Time:
      3:01 PM
      I turn the nozzle upside down when filling.
      • Like Like x 1
      • Agree Agree x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        45,687
        13434
        Oct 14, 2010
        Idaho
        Local Time:
        12:01 PM
        The vent line has nothing to do with filling the tank. What I mean by that, is that if you sealed the filler neck against a nozzle and depended on the tank vent it would build pressure
        The way these work (at least on the fillers I've seen) is that there is a divider inside the filler neck nearly the full length. It probably should have been longer, and maybe should have had a deflector inside the neck to insert the nozzle UNDER. The upper part of the divider is for air coming back up the filler neck as the fuel cascades down the "under" part.
        I also believe much of this is because of high pressure stupidity on the part of gas stations. There's at least one here locally I simply don't go to. At the time, it "kicked" the nozzle it had so much pressure. Felt like a high pressure hose. It puked all over a couple of my vehicles. I have a 69 filler neck I'll try 'n get photos
        Some photos of a 69
        Below, the complete unit. Vent is 1/4 tube, comes out near the top of the neck, up high against the inside top of the rear quarter, then bends down and follows the neck, down into the frame rail, where it simply open ends. You can see the bottom of the divider in the main neck sticking out at the bottom. It is leaning here towards how it sits in the car, except moreso. The gasket sits flat on the trunk floor, so the "U" in the vent line and the gasket are both pretty much level as it sits in the car
        Below, the bottom end. The lower part below the divider is gas flow, air going back out is in the top half. The divider ends about?? 10" from top of filler
        Below, a view through the filler neck. This is distorted, as the divider appears to come close to the top, but again, it ends some 10" or so from top. Fuel is in lower section as this is slanted, the air at top in this photo
        A good view of the vent. These seem to work well, and are simple. These use a sealed unvented cap, so if you REALLY got it full, and parked on a sidehill with the filler on the downhill side, worst that "should" happen with a proper sealing cap, is that fuel would siphon down the vent, drain out the frame rail, and onto the ground. The top cap area forms a "vacuum break" and as soon as the level would reach the vent tube, the siphon would stop
        Below another view of the bottom end. Fuel is lower, air is upper. You can see fuel section is somewhat larger
        • Like Like x 3
        • Rmoore
          Rmoore Well-Known Member
          445
          269
          Nov 14, 2018
          Gun Barrel City, Texas
          Local Time:
          2:01 PM
          I’ve been in the automobile business all my life !! I’m 54 years old now ! Every slow fill or no fill situation that I can remember being involved with was due to a venting issues of the fuel tank ! Whether it be mechanical or electric !! Maybe one case there was an actual issue with the fill tube!! Guys I’m here to tell you I don’t know everything.. and don’t claim to !! But I don’t understand plugging a vent in the fuel system and at the same time having a slow fill problem that’s caused by a venting issue ?? So apparently than can be another issue besides venting ???
          • Agree Agree x 1
          • 3rdLM23P9
            3rdLM23P9 FABO Gold Member FABO Gold Member
            670
            513
            Aug 8, 2012
            Sylvania, Ohio
            Local Time:
            3:01 PM
            • Thanks! Thanks! x 1
            • Dana67Dart
              Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
              5,304
              3319
              Jul 16, 2017
              Northern Colorado
              Local Time:
              1:01 PM
              A couple of observations / questions...
              Does the pump have a bellows that seals to the car filler opening?
              On my Dart, and my local gas station, there are no bellows. While I am filling I go get a couple paper towels and wrap them around the nozzle to effectively seal the nozzle tube to the filler neck. Not air tight but enough to catch fuel that might overflow.
              Also I insert the filler nozzle as far as it can go.
              Back in the day filler nozzles were larger in diameter. I think that makes a difference.
            • Mr Dart
              Mr Dart Active Member
              38
              5
              Dec 6, 2008
              Finland Europe
              Local Time:
              10:01 PM
              I do the same thing when filling my -64 Dart.
            • Bob Jasinski
              Bob Jasinski FABO Gold Member FABO Gold Member
              140
              35
              Mar 7, 2019
              Danville CA
              Local Time:
              12:01 PM
              My '65 Barracuda is apart, and I've been concerned about this problem too. 20 years ago I had gas leak onto the quarter panel of a freshly painted car damaging the finish, don't want to go through that again. Just took the filler tube assembly from the '65 off the shelf, tried to blow through the vent tube and couldn't! It was plugged and I didn't even realize it, blew compressed air through it and some dirt and fine rust particles came out. Before I install it I'm going to run a speedometer cable though it to really clean it out. Wheelsport, thanks for bringing this up!
              • Like Like x 1
              • RedFish
                RedFish Well-Known Member
                24,596
                3082
                Sep 5, 2007
                Local Time:
                3:01 PM
                i think it was Laysons that offered a modified filler tube for the early a-bodies.
              • Bob Jasinski
                140
                35
                Mar 7, 2019
                Danville CA
                Local Time:
                12:01 PM
                I just looked through Layson's catalog and couldn't find anything regarding a modified filler tube for an early A body, so if you know what the differences are, I'd like to know. I'm also curious as to how the tank vents to the atmosphere because I think the gas cap is non-vented (my cap is not here right now to examine).
              • Rick@Laysons
                Rick@Laysons FABO Vendor FABO Vendor
                1,734
                741
                Apr 25, 2005
                Lakewood, WA
                Local Time:
                12:01 PM
                Filler Tube Conversions
                FIX THAT QUARTER PANEL FUEL SPILLAGE !!! Here we have converted filler tubes for 1963-66 A-Body Mopars (Darts, Barracuda's, Valiants) that will eliminate that fuel spillage on the Newly painted quarter panel. Our conversions include original filler tubes that have been converted internally so that you keep that stock look, New filler tube tool, New filler tube to body gasket and even a New filler tube vent line. Road tested for over 6+ years and counting on various A-body models and up to 70mph on Highway onramp cloverleafes.
                P.S. CORES>We accept good cores only - must not be broken, ripped, torn, excessive rust (cancer), or warped to qualify as a good core and MUST be submitted with 90 Days of Invoice Date!!!!
                RN-636AFTC 1963-66 A-Body Filler Tube Conversions (with core exchange) $ 179
                RN-AFTCORE Core Charge $ 120
                LA-7526PD1 1963-66 A-Body Filler Tube plug – replacement plug (this is not listed in catalog or website) $ 12.50
                • chinze57
                  chinze57 Push Button tranny and a Slant 6 that'll never die FABO Gold Member
                  261
                  34
                  Nov 6, 2019
                  Georgia, USA
                  Local Time:
                  3:01 PM
                  I might need to give that a shot on my ‘64. The weight of the handle pulls the nozzle away so I end up having to hold it. Perhaps upside down will help
                • famous bob
                  famous bob mopar misfit
                  17,862
                  7310
                  Aug 14, 2011
                  okla
                  Local Time:
                  2:01 PM
                  SIMPLE , VENT PROBLEM -------------
                • chinze57
                  261
                  34
                  Nov 6, 2019
                  Georgia, USA
                  Local Time:
                  3:01 PM
                  I’ve got different issues with fueling as well. I can get 10-12 gallons total in there (out of 18) and then it starts to leak. Seems to be coming from where the filler neck meets the tank. I have a new gasket on the way to see if that will fix it
                • famous bob
                  17,862
                  7310
                  Aug 14, 2011
                  okla
                  Local Time:
                  2:01 PM
                  lube both the gasket and the new tube .
                  • Like Like x 1
                  • chinze57
                    261
                    34
                    Nov 6, 2019
                    Georgia, USA
                    Local Time:
                    3:01 PM
                    Do y’all sell the converted filler tubes or do we have to send in our own to be converted?
                  • toolmanmike
                    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                    54,288
                    40085
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    2:01 PM
                    I think @slantsixdan mentioned those in a thread a few years back. May be he has tested one and can give us a recommendation.
                  • chinze57
                    261
                    34
                    Nov 6, 2019
                    Georgia, USA
                    Local Time:
                    3:01 PM
                    It appears that it fits in snuggly with your filler tube where the gas cap is, reducing the diameter there to properly fit a modern pump. I’d be interested to see if that works, as it’s significantly cheaper than getting the tube recored to fit
                    • Like Like x 1
                    • toolmanmike
                      54,288
                      40085
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      2:01 PM
                      Exactly. For $15 + shipping it would be worth a try.
                    • chinze57
                      261
                      34
                      Nov 6, 2019
                      Georgia, USA
                      Local Time:
                      3:01 PM
                      Ill order one and give it a shot. If it works I’ll let y’all know, if it doesn’t, I’ll let y’all know that too
                      • toolmanmike
                        54,288
                        40085
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        2:01 PM
                        Perfect. I could use a couple myself. My 66 is worse than my 70 Swinger but I am careful with the Swinger. It has paint! LOL
                      • Dana67Dart
                        5,304
                        3319
                        Jul 16, 2017
                        Northern Colorado
                        Local Time:
                        1:01 PM
                        Hi Rick, would you be able to share some photos of what you all do to the fill tube. Also do you do 67 and up Dart etc?
                        • Agree Agree x 2
                        • Like Like x 1
                        • chinze57
                          261
                          34
                          Nov 6, 2019
                          Georgia, USA
                          Local Time:
                          3:01 PM
                          My 64 Dart is missing paint right under the gas cap where it’s all been eaten up by the mess that Is fueling with a smaller pump. Hopefully this will prove good and hold the pump in place, and Prevent spillage
                          • Agree Agree x 1
                          • Dartsun
                            Dartsun Mopar Dude
                            1,641
                            1222
                            Feb 12, 2012
                            Springfield Oregon
                            Local Time:
                            12:01 PM
                            My 65 dart spews the gas on fill. The only way I’ve stopped the issue is to slowly fill it and listen till it’s close and stop. All my fuel tank stuff is factory.
                            • Agree Agree x 2
