'Headers' vs. 'Exhaust Manifolds'
Just what does a set of 'typical run' Headers deliver in Horsepower gain
over a set of 'factory stock' Exhaust Manifolds in a 'Stock Engine'.
For one, there is a difference between 'Big Block' and 'Small Block' in
Horsepower gain.
~ Small Block ~
Generally, most of the 'exhaust system experts' state that a set of
Long-Tube Headers with {1 5/8" Primary Tubes} will produce a
'minimum' of 15 Horsepower over the 'factory stock' Exhaust Manifolds,
and running thru the exhaust system piping {primary pipes, mufflers
and tail-pipes}.
In other words, a set of 'Street-Type Headers' running closed and connected
to a conventional Exhaust System should gain you +15 Horsepower.
Horsepower gain.
~ Small Block ~
and tail-pipes}.
