I thought the header themselves fit easy. The issue was where they dumped out. You need to make custom headpipes and it was real tricky and tight.
""""Anyone run these that has ran thier exhaust to the back for a traditional hookup?
There was a on here from Sacramento (Kirk Ingram) that put a set of these on a 67-69 Barracuda years ago and had issues. Maybe hedman has changed things. Doesn't look like it from the pictures.
Whats the tricky part ? If they fit how hard is getting it hooked up to the rest of the exhaust ? Can tou explain .
WOW! Great news dak! Keep us up to speed and give us some pics for fodder tooI found a set of these at the swap meet yesterday, they indeed do fit a power steering car, there us a very small amount of rubbing on the gear box, i just need to massage the tube a little bit and barely hits the torsion bar mount with the collector. I'm talking a hair. As i install these ill be taking photos of progress, I did have to jack the motor up because of the power gear box, but it wasn't much at all and only drivers side.
:notworth: you are the teacher, I am the student... meditate on this I will... :notworth:Grasshopper (MT) If I have taught you anything it's only metal.
Andrew
Ive heard to use these short headers you need to change out the stock starter motor for the mini style starter. Is that true? how expensive are those mini starters.
any updated pictures?Just put these in an hour ago. They went in super easy! Only problem I see is that the passenger side dump is partially over the steering linkage so you cant come straight down with it like the drivers side. You'll have to make an immediate 90*/45* from the header then another 90*/45* down. Not too hard to do really just the only set back. They are super loud by the way.... no running open headers with these hahahahahaha
