streetdak
haha, i got mine on and installed the summit exhaust system yesterday as well! Random timing eh...??
The Good:
I was able to finally put a full 2.5 inch exhaust on my car, and now only need to rebuild the carb to get it back on the road.
Sounds good and was the first time i've ever fabricated exhaust myself and wasn't too bad.
The Bad:
Yeah, ground clearance sucks! I doubt my passenger side pipes are more than 2.5 inches off the ground, infact its lower at the moment because the exhaust clamp is facing bolt down.
Realistically these prob won't work for everyone, I'm just going to have to crank a lil on my torsion bars to raise the front of the car up, and then watch out for speed bumps!
Overall:
I would only recommend these headers to someone in my same position.
Someone who has a out of whack K Member that makes it almost impossible for good header fitment. I still may make some adjustments to the pipes to raise them up a bit, but you definitely HAVE to either go under the exhaust or go with smaller piping.
The Good:
The Bad:
Overall:
