Two carbs and three pedals.....
If i'm going to add a 3d peddle it will be Clutch-o-Matic
fluid drive from a 52 Dodge ?If i'm going to add a 3d peddle it will be Clutch-o-Matic
...727, remove Torque converter, hack bell housing off, bolt scatter shield on, flywheel, clutch pressure plate,.........add 3d peddle and slave cyl.
Aka a Clutch-O-Matic!!!!!!
You would think after 25 pages there'd be some kind of miracle answer LOL..Was this stumble ever solved?
What was the problem? Wrong bleeds, float level, PV ?
You all want to keep beleiving in miracle potions and easy tuning, go right ahead.
That's my Cliff Notes version of this thread.
If you read as many hot Rod magazine as YR you'd be bound to know something... LOL..Well, it's defiantly easy to spend money on a holley, but I don't think YR would have suggested it, if he didn't think it would help. Not that type of man, and has a funny way of being right.
Maybe I should take a month to read the entire thread...
Personally, I thought it might be an issue with the low bleeds being too large, causing a delay in booster draw. The stepped downlegs atomize well, but don't offer much in increased signal like the annulars.
LORD? was the stumble fixed??
If you're looking for the original poster of a thread it's usually on page one post one LOL.... after all this time even I know without barely reading much of it that all you've done is spent a whole crapload of money and gained a whole bunch of knowledge and still have the same problem LOL... now maybe someone can talk you into a Data logger and we'll find out how deep your pockets are...... ...For those that give a !@#%!#@% about this thread and not just having fun
There is not a answer yet!!!!!!!!
For all of you, i will tell you this.
I hate! yes HATE!!!!!! Searching threw a thead to find the original poster of the thread..............had gave up.........for whatever reason..............whether it's 1 page or 100 pages!!!!!! without give the "i have never figured it out".......OR "I have figured it out and this is what i found".
I have two complete Carbs now, and need to test them both.
I promise, this thread will NOT die without at least the results and some data on both carbs.
I want to say that i have found the problem and this is what it is..............But i have no proof or data to support my assumption.
I appreciate those that still have some interest in this thread after so many months and pages. For all your help, thoughts and ideas......I SAY THANK YOU!!!!!!!!
There IS a list as long as my arm for the potential reasons for my stumble. From the simplest of answers to the more complicated ones.
If i feel either carb need more than a jet change or squirter change . I will start a new thread.
Aka Iab Mab, Pvcr drilling exc. Flatting my fuel curve We will discover that in a new thread. I need my data logger for my o2 meter to Data Log before i can go down this road any ways.
This one is all about a Demon car Stumble.
Hopefully this doesn't become another bickering, for two more pages, before i get time to do some testing.
I've wanted a datalogger, since Quik Data 20 yrs ago. I can afford one NOW!
Just haven't been able to get off my wallet.. .. . wallet's not thick enough anyway.
I’m looking at the RPM data logger because it’s fairly inexpensive, is expandable, can log clutch RPM easily and I like what I’ve seen of the software.
I agree with Dwayne, you made a lot of progress here.There is not a answer yet
