yellow rose
Overnight Sensation
Yup. I'm off the reservation.
Hit me back when you can spell out the details.
So, if it only works on the pump-shot
does that mean it does nothing during cruising, and
once the pumpshot is burned up, again it does nothing?
If that is correct, I think it will be a hard sell.
It doesn't NOT atomize the fuel more efficiently. It reduces exit losses at the bottom of the carb. If your manifold is well prepped, and your carb is half assed tuned those things do very little to nothing.Not one of these is it?
Would certainly perform a similar function - atomising fuel more efficiently.
- boingk
My abs and neck muscles beg to differ with you. I am feeling some serious horses and I am Dying to find out how many it is...
I wish I could have you drive my car before and after this thing.
If you can hang on a month, I will have some professional dyno tests done and post the data sheets in PDF.
But I am trying to figure out what is going on with this thing still. I am getting some pretty significant HP and Torque increases, but the Patent Office is backed up and it will be at least a year before I hear back from them. I have more testing to do. So hang on for the ride. I know this thing is increasing HP and Torque. I may not know just how yet, but trust me, something is going on and I'm going to figure it out. I just don't have deep pockets, otherwise I would have figured out already... If it is not vaporizing fuel better, then how am I getting even 40 more horses out of the same amount of fuel. What could possibly do that then?
Thanks for your patience...
Wasn't talking about your deal. I was referencing that 4 hole spacer.
I'm patiently waiting for you to finish your R&D.
Ohhh Okay. Cool. I will let you know what the results are from a more reliable dyno shop and a more targeted area, low end.
No offence OP, this may come across as grouchy but you need to stay away from anything that requires mathematical calculations. Just stop.
Let's break this down.
You say you gained 170 lb/ft at 2600 rpm for a gain of 84hp by sticking a homemade device under the carburetor.
You claim that it was an increase of 35% over the same engine without your device.
84hp is 35% of 240hp
240hp @2600rpm = 485lb/ft
That's already impossible for ANY naturally aspirated 360, much less a mild one. and it's before your device SUPPOSEDLY added an additional 35%!
SO NOW WITH THE DEVICE.
485 + 35% is 654 lb/ft @ 2600 rpm.
654 lb/ft at 2600 rpm in a mild 360.
That's 324hp... At cruising speed. From a mild 360. Get real!
I can believe that an off it's chain race spec 408 could make 650lb/ft at 4500-5000rpm. But a mild 360 at 2600? what you're claiming is an actual miracle. Totally impossible. Wrong wrong wrong.
Check your maths.
Better yet, get someone else to check it for you. You obviously can't get it right. Coz it's definitely a loooooong way off.
Check your maths.
I can get 654ft/lbs of torque out of a mild 360 in first gear at the rear wheels at 2600rpm. It's all about gearing all it takes is about 75ft/lbs of torque at the crankshaft. It doesn't increase the actual horsepower though.
His tests need to be measured at the crankshaft on a properly tuned engine, that will determine if his claims are real or snake oil. The driveline needs to be eliminated to get actual believable results otherwise it's hocus pocus.
Yes you can multiply torque with lower ratio gears but you CAN'T multiply horsepower.
He claimed an 84hp increase was an improvement of 35%.
That's 324hp at 2600rpm with the gain.
That ain't happening on no mild 360. No way. no how.
Im calling it. It's officially a bullshit claim. (Probably unintentionally bullshit though)
I am not impressed with the dyno operator's job. He brought it up to 2000 RPM in 3rd, and "gradually" increased the throttle to 4,500.
Honestly, I could not have any less interest in it. I'm just trying to make you appear like more than a dreamer with a keyboard.
