Dusterdenovo
Contentedly Old School
So I'm installing my new front sway bar, and the last thing to do is connect the end links. Problem is, with the thickness of the LCA brackets and the sway bar and the stiffness of the new bushings, stuff not quite lined up etc., I can't get everything squeezed together enough to get the nut started.
Tried using a floor jack, bar clamps, kung fu grip........, so far no luck. Thought I'd turn to FABO for what is probably an easy solution?
Thanks, Larry
Thanks, Larry
