whiteeagle
Gonna sound like everyone else but, I would put those plugs back in. I always believe the $200000.00 a year engineer is smarter than me.
Arp main bolts? I had to clearance my pump for these bolts.Wouldnt bolt up flush but looked good at a glance.Just went to the blower thread. I had the same bolts Jack.I had to grind the **** out of the pump for clearance.I sure hope this helps.
Do you mean ARP studs Pete? Every SB I've done using ARP studs had major interference issues with the pump not allowing it to pull up tight. I usually spot face the main cap .050" on the side where the stud hits, trim the stud down just as short as possible, use a thinner nut and washer (grade 8 of course) and grind a little on the oil pump then it clears.
As for a couple other things mentioned
1. the plugs behind the cam plate. I've torn down engines without them that had no oil pressure issues. I also once had a fresh 360 with low oil pressure and when I took it apart I found those plugs missing and thought aha! I found the problem. Put them in and no change at all. Found the lifter bores worn badly on it causing the low oil pressure. Even though I've seen those plugs make no diff. I still install them just cause.
2. The head gaskets CAN NOT be installed backwards. Anybody that thinks they can must have a block with no dowel pins. Those dowel pins are offset to prevent installing the gaskets backwards. I attached a pic showing them being offset
3. Oil feed to the rocker shafts is only a few degrees of rotation so the cam has to aligned nearly perfect for the oil supply holes to feed the rocker shafts so the only way you will have oil pressure to them is when the engine is in exactly the right spot of rotation and it's different for both sides.
Check out the last picture I attached showing a commonly missed oil galley pipe plug that will cause very low oil pressure if left out. I think you said you checked it so sorry to be repetitive. Just want to make sure.
for some stupid reason would the head gaskets be the magnum style without the oil hole. i know its sumtin stupid like that jack if it was obvious u would have found it by now.
thanks for the info louis i was not 100 percent sure on this as i am not right familar with the magnum engine but i should get my facts straight there is enough bad info out there.Pretty sure the magnum gaskets have the oil hole also. I used magnum Felpro 519SD's on one of my strokers that had LA Heads & Block. I did this because the compressed thickness was .054 "pistons were out of the hole" The block is where the oil is restricted for the Magnum's, not at the gasket. "block is not drilled to supply oil to the heads"
Thanks for all the suggestions here. I did not know about the plug in front of the dizzy. I don't think it is my problem as I would have oil shooting all over the cam gear area if it was missing and I don't. I will check to make sure.
That's what I always figured as far as the head gaskets. I have the dowels and they are offset. Impossible to install head gasket wrong.
I have ARP main bolts. I will check to make sure there is clearance for the oil pump.
As far as the bearings are concerned, I mic'd them and plasti-gauged them.
If I remeber right, the clearance was about 0.0027 on the mains.
I am going to install a new oil filter today. If that makes no difference I am going to take the oil pump apart.
Lots to check today.
Jack
