Ironracer
Gearhead
I just don't get the fact that it went into drive fine when it was cold... I'm stumped
Now wait a minute. Up there ^^^ you say you have it idling at 650. So which is it? 650 or 1200? Why would you idle it up to 1200 if it'll idle at 650?Timing is @22° according to a Matco dial back, still pulling vacuum in park @1200 rpm.. need to locate a piston stop..seems like she wants more timing. Fires right up, no drag on starter
He was advised to crack the secondaries open slightly because he was pulling vacuum on the spark advance port at idle. That's an indication that the T ports on the primary side are too far exposed, so to make up for it, he was advised to pull the carburetor, get the primary T ports square and crack the secondaries very slightly. It's a very, very common practice people have done for decades, along with drilling the throttle blades. I don't like drilling the throttle blades, because that's irreversible. Playing around with the T port exposure is not.With your secondaries cracked open you are loosing all of your vacuum at an idle, then in turn your vacuum advance is doing nothing because there is no vacuum there to pull the vacuum advance so it dies when the idle drops when you put it into gear.
Over the internet diagnostics, no easy task . . .
Sounds to me like you are closer now, but have at it. I sure wish we were local. I would figure it out for you.Well, just finished dinner. Went back out, fired it up, gave it the smallest pedal w/ foot brake, and it stayed running in gear. Probably just need to close the secondaries back up, and leave it the heck alone! I'm not a professional carburetor tuner I may be trying to get this thing dialed in " too much"... lol. I know I had less problems when I didn't mess with it! Thanks George!
I know we'd help each other out, that's how it supposed to be....This thing has my *** chapped... lolSounds to me like you are closer now, but have at it. I sure wish we were local. I would figure it out for you.
I closed the mix screws, brought em to highest idle (2.5 out) and messed w/ the timing...Now wait a minute. Up there ^^^ you say you have it idling at 650. So which is it? 650 or 1200? Why would you idle it up to 1200 if it'll idle at 650?
I never touched the idle adjustment screw, per Your instructions, Boss! I promise that!Now wait a minute. Up there ^^^ you say you have it idling at 650. So which is it? 650 or 1200? Why would you idle it up to 1200 if it'll idle at 650?
2.5 out? should be 1.5 max.I closed the mix screws, brought em to highest idle (2.5 out) and messed w/ the timing...
When I pulled the plugs, after pulling it from the ol 66 Sat, they were healthy grey...with points. It the carb I got when. I built the mill. Ported heads, oversize valves, 155 psi, full Grove mains, 8 qt pan ( never again, lol) ARP rod bolts, std bore TRW forged pistons, high volume oil pump, strip Dom, just a fun Lil mill, w/ reliable street ability...2.5 out? should be 1.5 max.
I think you should look for a vacuum leak.
Holley 750's are factory spec'd for 396 Chevy. if anything it would be rich for a mild 340.
The damn thing was fine.. the only odd thing was, I gave er a Lil wing, and a spit out the primary popped out. Never before w/ that combo....2.5 out? should be 1.5 max.
Thank You fer articulating that properly...He was advised to crack the secondaries open slightly because he was pulling vacuum on the spark advance port at idle. That's an indication that the T ports on the primary side are too far exposed, so to make up for it, he was advised to pull the carburetor, get the primary T ports square and crack the secondaries very slightly. It's a very, very common practice people have done for decades, along with drilling the throttle blades. I don't like drilling the throttle blades, because that's irreversible. Playing around with the T port exposure is not.
It's 12 years old. Seen some dragging, and a few years of street use, daily, I'd hate to think i killed the Throttle shafts...what's odd is the Darn thing, after following RustyRatRod and Mattax instructions, to a t, she fired up and idled at 650, then dropped to 450 in gear.. then I tweaked the idle mix screws out, that raised the idle... checked w/ a light, timing was to advanced, so I retarded the timing. At some point, I gave it a little gas, and got a pop outta the primaries. SOB never idled since... Thanks Kim, hope all is well, ChuckIf it only started doing this since u cracked the secondaries open wouldn’t it stand to reason to close them back up? And if ur pulling vacuum where it shouldn’t be the carb surely needs a rebuild at least. May have worn throttle shafts also. It it was great with points try installing them again. Kim
You might should have tried the idle screw instead of the timing. So where are you now with it? Will it still not idle?It's 12 years old. Seen some dragging, and a few years of street use, daily, I'd hate to think i killed the Throttle shafts...what's odd is the Darn thing, after following RustyRatRod and Mattax instructions, to a t, she fired up and idled at 650, then dropped to 450 in gear.. then I tweaked the idle mix screws out, that raised the idle... checked w/ a light, timing was to advanced, so I retarded the timing. At some point, I gave it a little gas, and got a pop outta the primaries. SOB never idled since... Thanks Kim, hope all is well, Chuck
Does it have power brakes? Or does it have some vacuum caps? A lot of times, when one pops, it'll blow off a vacuum hose or cap and induce a manifold vacuum leak. Ain't gonna idle like that.
NO!Is it normal to idle over a grand, yet drop into park, lose 5 or 6 hundred then stall?
It still dies when I put it in gear. Idles nice.. lolYou might should have tried the idle screw instead of the timing. So where are you now with it? Will it still not idle?
Yes. Has some Viton (or whatever) caps. And darn power brakes. Newer masterDoes it have power brakes? Or does it have some vacuum caps? A lot of times, when one pops, it'll blow off a vacuum hose or cap and induce a manifold vacuum leak. Ain't gonna idle like that.
It has the power valve blowout protection... but I guess I can get some gaskets and rip it apart.... unfortunately I'm supposed to work todayI'm no holley expert, but a pop can break some parts. Mostly the power valve I'm told.
Might be worth a look-see. Lots of instructions in how and where and what to look for on google.
Supposedly holley "fixed" the power valves to not fail after a pop, but if the pop preceeded your issues... Well, there it is.
With your engine combo and converter the idle speed in park should be more like 850 -875 rpm.It's 12 years old. Seen some dragging, and a few years of street use, daily, I'd hate to think i killed the Throttle shafts...what's odd is the Darn thing, after following RustyRatRod and Mattax instructions, to a t, she fired up and idled at 650, then dropped to 450 in gear.. then I tweaked the idle mix screws out, that raised the idle... checked w/ a light, timing was to advanced, so I retarded the timing. At some point, I gave it a little gas, and got a pop outta the primaries. SOB never idled since... Thanks Kim, hope all is well, Chuck
Cool, I'll make an attempt to target that #! Thank You!With your engine combo and converter the idle speed in park should be more like 850 -875 rpm.
