Aussie Charger
So how does a rocket produce thrust?
Really?A rocket engine has no moving parts – how do you explain acceleration of a rocket?
Combusting JediWhat moves a rocket?
noIs horsepower a force?
And it's how often that force is applied is what that matter to us, what powers us down the road and we call it hp. We can calculate how much hp needed for quarter mile , top speed, hwy speed, towing etc...Answer: No. It is a measurement of how often a force is applied
Well . . . there are other ways of multiplying the force. You could have a lot of torque at a low rpm and still produce a lot of horsepower. V8 vs 4-banger for example. There's also a reason why torque and weight are credited with breaking parts and not horsepower . . . because torque (force) acts agains weight (mass) to produce acceleration.And it's how often that force is applied is what that matter to us, what powers us down the road and we call it hp. We can calculate how much hp needed for quarter mile , top speed, hwy speed, towing etc...
Done done done
rocket engines produce thrust by the expulsion of an exhaust fluid that has been accelerated to high speed through a propelling nozzle.... ant got nothing to do with a 4 stroke internal combustion engine....DWB!So how does a rocket produce thrust?
@273 the more efficient(better designed) a port is, the higher a velocity it can operate at. High velocity is "free" supercharging, augmented by complimentery runners. They actually work better with smaller valves because more curtain area is used, which allows for less shrouding as well. Poorer ports tend to work better with larger valves deshrouded because they need as much low-mid lift flow as possible to crutch poorer high velocity flows, most OE ports are poor to decent. Very few are great, but some can be modded to be very good/great, so that's where it stands.
Yep. I am trying to steer this thread back onto the original track, lol...That's a good generalization.
There's also some practical considerations.
Higher velocity means higher momentum and smaller turning angles. A smooth port that's as close to straight as possible can function well at higher velocities than a port with sharp changes in direction.
There are upper limits to port velocity even when perfectly straight, and it can get complex. Especially as it flows across the valve and into the chamber and expands.
Basically: it depends.
The carb, heads, and intake all need to match the intended flow capability of the shortblock.
Agreed, it's not an automatic, & even wet-flow testing can let you down. I used to high-speed videotape through an acrylic cyl. while dusting white flour over the intake manny, watching where the major flow was taking it. It was half-assed I guess, but at the time, it was still eye-opening some of the things it showed Me.If you are going to port heads velocity management is imperative.
Just standing at a flow bench and getting more flow and running the velocity up can get you in trouble.
A running engine isn’t static, and adding fuel to air changes everything.
Ive seen way more heads with a bunch of velocity lose power because once you add fuel you change everything.
I agree velocity is important but I think over worrying about leads to strangling your engine, say you have a zero decked 367 with a xe285hl cam, for most their choices for heads is what is available, at the very least stock 1.88 heads and max for most trick flow. It comes down to $$$ and how much power for most they have little control over it.@273 the more efficient(better designed) a port is, the higher a velocity it can operate at. High velocity is "free" supercharging, augmented by complimentery runners. They actually work better with smaller valves because more curtain area is used, which allows for less shrouding as well. Poorer ports tend to work better with larger valves deshrouded because they need as much low-mid lift flow as possible to crutch poorer high velocity flows, most OE ports are poor to decent. Very few are great, but some can be modded to be very good/great, so that's where it stands.
Velocity like everything else about balance and compromises, too much of anything can be bad.
Doesnt seem to be many SBM heads that are "too slow" to begin with either.
I think people worry themselves with port velocity to rationalize not going to greater lengths with their porting. Over-porting seems mostly to be a worry when people focus on the wrong areas and wind up with wide and narrow spots along the port or just blow out areas that are easy to reach.
Or they just ruin really important spots thinking they're improving things...
Also because people are cheap and think offset rockers are too complicated.
You better be careful or @Rat Bastid will die of elation that someone else get's it lol. Seriously, it's nice to see some smart, articulate people who understand what the hell is going on. I'm guessing some of these guys are getting bad drinking water or something because the stuff they come up with is mind boggling.Doesnt seem to be many SBM heads that are "too slow" to begin with either.
340 is slightly on the small side and a fairly low power with reasonable powerband, never heard anyone say 340 would be better off with smaller port now most start with a 360 thats 20+ cid over a stock 340, ideally at minimum you think you want to start with a head slightly more port then a 340 even for a mild combo nevermind something with some teeth to it. Even a 318 is only slightly smaller than a 340 especially with an overbore, it has heads originally designed for a 273.
