JGizmo
Took the head off of a rusty slant six and this is what the cylinders look like. The rocker arm/valves were covered in surface rust. Is this recoverable?
Down and dirty,low buck down backyard get er done. I like it!Pull pistons and clean the ring grooves, dingle ball hone it and run it. Its a slant...its replaceable. Whats the worst that could happen?
And to blow out the rest of the rust... Itll only increase the power by 50%!And a 50 shot of nitrous to test for cracks
I know that's right!Man,, theres a alot of quitters on here with to much money, Pull it apart dingle hone it feel for indents and imperfections that can catch your finger nail. If they catch your nail bore it and smack.new pistons in the hole and run it. I built a 360 that was in my eyes no way.it was gonna work and 4 years later still gettin the dog beat out of her shes got blow by but.wow tbat engine gets beat
There are tons of old boats in the harbor. I thought all boats came with them at the end of the chain.I have a slant six that was given to me by a member here. It was so rusted up I had to press the pistons out on my press. One cylinder was cracked badly. That's the only damage to that block. I will clean it up and get a sleeve put in it and get it bored .030. I cannot imagine how tough these will be to find in ten more years.
LOL May have. I wish I could find a cheap source for cores. I get um.There are tons of old boats in the harbor. I thought all boats came with them at the end of the chain.
I killed one.... am I proud? No....That is easy... Yes
If the connecting rods are still attached to the crank... which I'm sure they are.
Just pull the crank and carefully remove the pistons. The ugly one you may break and throw in the trash. Clean the cylinders and go from there. That is the toughest engine to kill ever made by mankind.
