JohnFM3
Where did you acquire the upper shock mount hoops?
HDK (hemidenny is the owner). And they are rock solid. I love them. Here is a link...
HDK Front Suspension Parts For Mopars
I can’t give you any recommendations based on your setup but if you can use the wheels you currently have, it will save you some coin for something else.
Denny is the best, and he has great products. He really helped me with my swap when I got into my own way! Just a great guy and has forgotten more about Mopar geometry than I will ever know. I am still rocking his front end.To my friends in the community.
Many people here have been a big help and inspiration while I have gone thru this process. And I thank everyone. I want to take a moment to make a shout out to HemiDenny at HDK who has gone over and beyond trying to help me with the AJE suspension system I bought for this project with many emails and communications.
After alot of persistence and support by HemiDenny, I came to the decision to no longer fight that kit to be used in a way it was not meant and follow his suggestion in utilizing a more OEM style setup.
In the end, I have installed the OEM K-Member back in the car. With purchase of additional parts needed, I now have the following going into the car...
73 - 76 Steering link components including the V8 center link
73 - 76 Power Steering box
73 - 76 Lower Ball Joints
73 - 76 Steering Knuckles
73 - 76 Rotors with big bolt pattern
HDK Upper Control Arms
HDK Lower Control Arms
HDK Shock Hoops
HDK steering column shaft for use with Flaming River knuckle style coupler
QA1 Shocks and Coils
I need to purchase front single piston brake calipers and other brake components. I will also be picking up a Ford8.8 (3.73 with limited slip) and having the long side narrowed ~3in to utilize the shorter axle shaft on both sides so it fits under the car. That will get me a rear end with large drum brakes and a easy bolt-in upgrade option to disk brakes in the rear of the car with a big bolt pattern matching the mopar fronts. May Mother Mopar forgive me for using a ford axle in my car... lol At least the engine will be a Chrysler Era.
Once the car is back on the ground, I will start looking at what needs to be done to fit the Jeep 4.0L in the car. Have to look at whether to modify the oil pan, notch the K-Member, or both. I am also wandering about considering notching the firewall 2 inch deep to allow the engine to sit back a bit further. More to follow on that.
The big thing I care about is avoiding the need for a fiberglass pro-stock hood with a full length cowl induction scoop to fit the engine under.
This project had not stopped. It was just stalled a while during which I had to do some thinking and make some choices. I will be moving forward with more activity on it in the coming months. The suspension parts are being shipped now, I plan on having a update on this thread in the next month after getting the front end on the ground. Pictures to come at that time.
Again, "Thank You" everyone, and a big "Thank You" to hemidenny
So I made my second and final payment for 2 parts cherokee's this weekend. And the person I purchased them from is willing to hold on to them till after the move to the new house. Hopefully it doesnt come to that. I really hope to get them yanked over to my current house this Fri, stripped down over the weekend, and towed out by next weekend. But we will see.
Both cherokee's are from the Renix 4.0L era when GM owned jeep (1988 an 1989). 1 is a 2wd and the other is a 4wd. Though I plan on running the H.O. injection, Electronics, Harness, and ECU, the engine's head will not be swapped out for a H.O. till after fabrication and the project is road worthy.
In a 4cyl to 6 cyl conversion project I tackled on my sisters wrangler, I ended up with a second complete wiring harness. I just need to buy a ECU if I want to keep all Jeep electronics. There is the possibility of selling it all and purchasing a MegaSquirt3 ecu and building my own harness.
I will have a 2wd AW4 4sp auto tranny. Its a real bomb proof tranny which has proven itself time and time again in the trails with the 4wd version. There are threads on this forum of people installing one of the Grand Cherokee's V8 trannys which is a true dodge tranny. I may use the AW4 for trade an see what I can get out of that.
Another thing I grabbed which may be beneficial (or not), a Grand Cherokee Dana 44 with 3.73 gears. The bonus is its already setup for 4 link suspension. The draw back is it has a Aluminum Diff with steel axle tubes. Those of you who wheel would understand the issue. When off camber and side loading the axle, you run the risk of blowing the opposite carrier bearing thru the diff. I suspect that a much lighter vehicle such as a Mopar A-body (when compared to a fully off road capable ZJ or XJ) will not have much to worry about.
The last thing I have as a result of this purchase is a couple of usable drive lines now.
The best part of all this, as I noted above I have 2 engines. My 92 Wrangler is getting a replacement engine now as the one I am pulling out has well over 300K miles on it and has given up the oil pressure.
I build jeeps more than anything right now- I have 11. I am planning on opening a motorcycle and jeep rental agency in the next year. So this is a very interesting thread for me! I am kinda curious about the trans and EFI issues. I would guess the best bet would be to find an AX -15 two wheel drive trans 5 speed for it, and convert it to carb. No option for a mechanical fuel pump though- my "franken jeep" XJ has this set up. I see you are planning on using the 2whl AW4 and keeping EFI though- are you an electrical kinda guy? I found that to be a nightmare on these things. love to hear how you plan on working around it.
I’m excited for you! This sounds like it’s finally all coming together! And I’d like some feedback from someone actually rubbing a “truck” trans. Most people just skip that option since they’re not geared like a sports car but i don’t see why it wouldn’t be great on the street.
@75slant6 runs an AX-15 5-speed manual in his Duster behind a mild 360 Magnum and he likes it, the ratios go better with taller rear axle gears though (deep 1st, not very tall 5th) I think he's running 3.23s or 2.94s (?) They do have a pretty wide spread between gears especially 2nd-3rd but with a torquey street engine that shouldn't be an issue.
I’m excited for you! This sounds like it’s finally all coming together! ... Unfortunately without precise measurements for your wheels you probably can’t estimate how close they’ll be. I can check to see if they’d fit my car if you get me some measurements, though.
Yeah I’m running an AX-15 in my Duster, along with 2.76 gears and 25.6” tires. I had 3.23s in it originally and 1st gear was next to useless.Thats kind of what I am thinking. My jeep wrangler runs 33in tires with 3.73 gears. A Automatic (AW4) XJ Cherokee runs 3.55 gears. And many manual trans XJs run 3.23 Gears and a AX-15.
My current trans is from a 4cyl YJ Wrangler (Peugeot BA-5) which had factory 4.11 gears in it. On my axle I am starting with the 3.73 gears and going from there. Once the car is road worthy, I will put a replacement trans based on options. I am really interested in speaking with 75Slant6 now hearing that user used a AX-15 which is the targeted trans of choice.
Thanks,
John
Really loving this project, want to see these rims on the cuda man!
I used an external master/slave setup from a mid 90s s10. A previous owner had hacked out the tunnel with a torch for a 4 speed so I had to completely redo the tunnel and upper crossmember.Dude, thanks for reaching out. Crud, I was concerned about the gearing. My Ford 8.8 has 3.73 gears and a limited slip.
What I really wanted to know, do you have a internal or external clutch slave cylinder? How was the fitment in the trans tunnel? Any tunnel modifications required?
Thanks,
John
yeah with 3.73s you’re gonna need to put some 35” boggers on that barracuda!
