joedart
How many of you have built a motor with the 284-484 cam and made over 400HP also can you list your combo or some of it? Just curious of some variations.
Package eight:
360 rebuilt with 9.5 to 1 cast pistons, original crank, rods and windage tray. 202 heads with competition valve job and ported to flow 260 cfm. Edelbrock RPM intake, Holley 750 rejetted, Large tube headers and Mopar Performance P4120231 cam with .484" lift, 284 duration, 108 lsa, installed at 106 intake centerline.
460 h.p. @6000 rpm
486 lbs. of torque @ 4,250 rpm
My 360 has this cam. I don't know about 400 hp but kinda close. Runs upper 11's in my 3000 lb Demon.
MP 284/484.Flat tops, 2.02 valves with a mild port clean up. Torker II single plane, 750 holley. Pump gas.
I'm sorry but 460 hp from that 484 purple cam is a load of crap ...that is a 350 hp camshaft in the real world.
On a real dyno a normal 340 with a set of ported X heads/headers/intake/750 and with the sun and moon and stars all aligned on the best day 375 hp.
I've read a lot of stuff on this board that makes my eyes roll but from my personal experience on a real dyno it's just not going to happen.A 484 purple cam that makes 1.35 hp per ci in...not in the real world...This one I just had to chime in on.
Believe what you will...that 484 cam will always be a 49.95 cam with lifters in my book.
With exhaust manifolds and a low compresion, yep.I'm sorry but 460 hp from that 484 purple cam is a load of crap ...that is a 350 hp camshaft in the real world.
I agree, then any mis match will be that in my book.Believe what you will...that 484 cam will always be a 49.95 cam with lifters in my book.
Let me tell you guys something until you build this engine show some respect cause I sure am not feeding you a line bull@#$%. Just think like a pure-stock guy and rumage through hundreds of parts until you get those right pieces. Think outside the box. Oh, you'll like this even better with a cast iron intake it made 419hp-422tq and a thermoquad.
They are at best tools, and tools whose results can and are manipulated all the time.
The cam's good. not great, but good. If forced to use and MP product I'd take the MP .528 over it any day and make more usable power with it.
