That's for a needed reason, not just cause you don't want to run proper pistons.Here’s one for you. I had to mill close to .100 or a bit over that to get my pistons .048 out of the hole.
This is a general build, say the dude ends up wanting to try a few different intakes now he's got to mill each one and are pretty much useless to anyone to use after.The brand new Weiand tunnel ram I have fits perfectly with zero milling. I’d have been stacking gaskets if I didn’t need to mill the block that much.
I’m Just saying it might limit any future upgrade, now if there's zero chance for any possible upgrades then fine mill the **** out of it. But you might think there's gonna be zero chance then life happens now where trying to figure how to use this short block in a new project.
With no valve relief's ?I run my cam on a 105 ICL and LSA and I have more than enough p/v clearance.
Yes I'm not an engine builder, everything I've done been to a stock short blocks.Again, you don’t know what you don’t know.
