Different Gas? Might have something to do with your diet.I herd that summer gas is different than winter gas around here not sure what they do to it.
If you leave your car out side in cold weather you have to plug the block heater in and some times I for get. lol
Threw my straight line sander away years ago. I disliike those clogging groove sanding SOBs. If I cant hit it with my 8" DA, I do it by hand.The filler will work because I already own it! I do have a straightline body file and a DA so pneumatics are my friend!
I'm Kind of new to this thread MonkeyMadness. What is it that you do for a living?Morning Gents...
Last day of work for me....I'll be off for a week...
You going to work on the car or you going on vacation?Morning Gents...
In my case you bet mostly after I make my home made chili out of a can or meat loaf.Different Gas? Might have something to do with your diet.
All my trim is real nice but not going with a vinyl top I think.To be honest BP, I don't think I'll use it much. The car is pretty straight! I have some rust areas at the bottom of the rear window on both sides that will get new metal welded in and the lower front of the R quarters. Nothing real big, just shitty locations. I think I will not need more than 2 or 3 days for those spots once I get through welding. The tubs are 75% welded in, the frame connectors need finished and all the trim holes need filled.
Oh well, it'll keep me out of the bars for sure!
Fred, how's your vinyl roof trim? I won't be using mine. Oops, wrong body style!
Do what you love and do it wellAll my trim is real nice but not going with a vinyl top I think.
Not sure what it is JEFF. but a shitty one is hard yo control I think. What do you think BP.Question, I have a cheap (Lowes) DA - is it worth buying a better one?
Morning Biff how are ya.Do what you love and do it well![]()
Glad to here shes in good shape Jeff. sounds like you got most of the hard work done on the under side.To be honest BP, I don't think I'll use it much. The car is pretty straight! I have some rust areas at the bottom of the rear window on both sides that will get new metal welded in and the lower front of the R quarters. Nothing real big, just shitty locations. I think I will not need more than 2 or 3 days for those spots once I get through welding. The tubs are 75% welded in, the frame connectors need finished and all the trim holes need filled.
Their are definitely different grades of DAs. Cheap or not. I counted 7 different ones that I have and I use them all. The first car I painted I had zero DAs. Sooo there is that.Not sure what it is JEFF. but a shitty one is hard yo control I think. What do you think BP.
No, not much at all, some winters we don't get anyMorning Mike. I never seen snow there before must not happen much I would guess.
Pawn shops have to be full of DAs. Make sure it has a 6" pad. I like the 3" too. My go to is a Mac DA. super light and not too choppy. Some are like chain saws and some are fine as frogs hair. I have an IR that has a locking feature that turns it into a grinder. Kind of handy.I know prep is everything so if I need a better one I will not argue!
Who makes a reasonable one? Is $100.00 too cheap?
Hutchenson if I spelled that right is great. ingersol also. not sure on the price but around $300 or more. All my tools are old haven't bought any in a long time.I know prep is everything so if I need a better one I will not argue!
I see your best friend is visiting. Nice
