if that voice in the back of your head is telling not to sell your 340' cars, do what the f**k it says
Hey Asa I am doing better.Darryl Long time no see how are you . Pm me if ya need to
When you have your eyes on the part to see what the carburator cleaner is doing, make sure the can nozzle is pointing at the part, not your eyeball. I missed that once and it really, let me tell you, really sucked!
Always make sure that the old oil filter gasket comes off with the old oil filter
2 gaskets will not hold much pressure for very long.
what a mess
Good to hear bud just checken on yaHey Asa I am doing better.
For boosting cars place the negative on last to a ground point away from the battery,this keeps the sparks away from the battery.
Darryl
Done that . A few times hurts like all get outWhen you have your eyes on the part to see what the carburator cleaner is doing, make sure the can nozzle is pointing at the part, not your eyeball. I missed that once and it really, let me tell you, really sucked!
toss the plastic...... Yes do so ! Or is can give you a hart atack Going down the high way at 65 when it moves just enough to kink it and read 0When your over 40 and working under the dash...remove the seat....your body will thank you later.
And when installing after market mechanical oil pressure gauge, do yourself a huge favour and toss the plastic crap they give you and get the copper line....that way you won't be wondering why you right leg is feeling warmer than your left...
AL
When pulling the distributor out of the intake manifold on a small block, never leave
the hold-down bolt on the fire-wall/cowl area,
Or the bolt may fall directly into the distributor opening (Twice no less)
