75 model block I believe. Everything else is aluminum. Both my hoses are on drivers side.I keep forgetting to tell you my 71 DEMON also is a 440 you can get a relocating kit to move oil filterWhat year is youre 440 Like I said my 440 is a 73 both hoses are on passenger side
I kind of doubt it. It's a good radiator. The factory style hose for it will work. It's just going to rest up against the oil filter.Have u told the rad. manufacturer about it ? They may redo it for you .---yeah , right !
I've been giving some thought as to relocating the oil filter. I checked out Milodons relocation kit and it looks to be pretty good. I've never relocated the oil filter on any of my other cars so this would be the first. I was reading to where someone stated that it might cause a slight drop in oil pressure. Anyone encountered this before by relocating the oil filter?I keep forgetting to tell you my 71 DEMON also is a 440 you can get a relocating kit to move oil filterWhat year is youre 440 Like I said my 440 is a 73 both hoses are on passenger side
i've done a couple of them, never had an issue.Didn't notice any difference .Good luck
Each braided line is 24 inches long. Thought about mounting it on this hump below where the battery tray once was. On the part of the hump that drops off to the left.that will work. are the hoses long enough? 24" isn't very long. are you just going to the frame right next to the oil pump? use some heater hose to mock up the bends to where you want to mount it
For changing the oil and dropping the filter?
yup. there's a couple different ones out. they work better than aluminum foilFor changing the oil and dropping the filter?
Got the mechanical fan installed along with the electric pusher fan, transmission cooler and radiator overflow tank. The SPAL electric cooling fan sat a little too close to the radiator so I bought a rubber spacer they sell to space it 1/4 of an inch away. It is made for the 16 inch fan I bought and works pretty good. It's molded for the fan and attaches to the housing of the fan. Seals it to the radiator good as well.
The mechanical is made by Maradyne. It's called "The Texas Twister"..Who makes that mechanical fan? It looks good!
Installed my new radiator today. Bolted right up to the factory holes. May have to do a little hose searching as the lower radiator neck is 4 inches away from the oil filter. Cold Case makes one beautiful radiator. Looks close to stock but in polished aluminum. Tig welds look awesome.
