OH MY ! You make everything a project. lol were you a construction engineer before you became a master mechanic/race car driver. lol
Actually...OH MY ! You make everything a project. lol were you a construction engineer before you became a master mechanic/race car driver. lol
you are always so detailed, like a teacher I once had. not a bad thing.Actually...
What makes you say that?
Actually yes I'm very detail-oriented. it's part of the good and bad of my personality. I also use my voice command on my phone for most everything and I try to go back and correct, but you are getting exactly how I would talk to you if you were here. That's what gets me crazy about some of these internet Heroes that talk a lot of crap that they wouldn't talk to somebody's face..you are always so detailed, like a teacher I once had. not a bad thing.
I'll read the thread here in a couple minutes. But in lieu of that I put the Jets back in my old carburetor and Venom fired up just perfect and ran great like always. About 14 to 14.7 at idle.
That's funny I was actually reading that before I went out and tried the car this morning. I can see that there was some how did to the post but this is nowhere near what's going on with this carburetor. For whatever reason I think it has an internal passage or something that is not working correctly. Again I put my other carburetor on and immediately everything was running back to normal. The only way I was able to keep it to idle whatsoever was by turning up the idle on the front carburetor which never got messed with before.
I got this little pin cleaner with our Harbor Freight power washer last week and I use that to poke in all the little bleed holes. Fionn like I was saying blasting every single hole with carburetor cleaner making sure it blast it out the other direction on everything several times.I had an issue with the edelbrock on my truck after a rebuild, ended up being the air bleeds were cruded up even after the dip. I dont remember the size but cleaned them with a torch tip cleaner and not a problem since. Would be worth a quick check.
did you spray around the base with carb cleaner with it idling?You know I just thought of something! I wonder if the bottom of the carburetor is Warped? I remember the gasket on the bottom was what but it did not leave an imprint of the carburetor like my Carter did. That will be something I will check first thing.. A massive vacuum leak underneath the carburetor??
Well it wouldn't idle and it was starting to show like 18 19 and 20 on the O2 wideband and that is almost off the chart lean. I wasn't going to play with it. As you can imagine the car was warming up very fast and this was the first time I started it in three or four months and I wasn't going for that. I wasn't letting this one pile of crap carburetor blow up my motor. Again I put the Jets rods and springs back in my old carburetor and fired it up and warmed it up to warming temperature with 14 to 14.7 showing on the O2 sensor. It was hitting 13.8 quite a few times also I should say that. Also it was reving just fine when I with rev the front carburetor. But also when I manually read the front carburetor I can't see what the O2 sensors doing inside..did you spray around the base with carb cleaner with it idling?
No fan belt, electric fans...I always had better luck, using a propane torch, un-lit to find vacuum leaks, just take the fan belt off.
You run electric water pump too?No fan belt, electric fans...
I did til the last winter. I cut the cage out, de-camed it, and made a bunch of changes for more street comfort. It's on the Shelf still glued to the timing cover with the March performance reduced pulley and smaller v- belt..You run electric water pump too?
