I would have responded "who do I call?" I always assumed CNC was much easier faster and cheaper, cause after all ITS PERFECT!It's a learning process. Glad you ain't quitting. Make the best of it.
I still say you need a cam change to pick up the middle.
Keep us posted with how it goes.
BTW, I'd like to ask you a question, and you don't have to answer it if you don't want to, but it may help someone along down the road.
Question: Before all this happened, would have considered heads that were not CNC ported if someone told you they aren't as good as advertised and hand ported heads could make more power? What would you have said?
So to really answer the question, he'll yeah I'd have considered it, but you don't know who does them anymore or you figure it's too pricey due to time involved.
When I was a kid I had this 65 Chevelle. 427 4 speed mild Crane Fireball. It was fast for then. Heard about "this guy" who can grind on your heads a bit and make it faster. I think I paid the guy 75 bucks, did absolutely nothing else and went a half second faster the first Saturday out. Half a second.
faster yes, better I don't know about that. and who's data are we using.The cnc machine is a computer.........bad data in......... BAD DATA OUT!
There's no doubt about it, cnc will make every every port the same and many times faster than the best hand porter.
Hey dude, I know you ain't rubbing salt in my wounds. My point was old Mr Santucci picked me up .5 just by his hand porting. I think it's a dying art, business-wise. How can a guy charge someone what his time is worth.They guy who developed the Bloomer head is still grinding ports.
Trust me, I'm trying to rub salt in your wound. I'm hoping that someone else will see this and learn that CNC does NOT assure a quality port. If the port copied was junk, the CNC will just repeat it. Since 1980 I have seen way more junk ports than I have good ones. Especially on the exhaust port.
Yep. Talked to Mr Bloomer today. Has them on the shelf. I'd be the first buyer. He got a motor on the dyno, break in went well and the dyno developed problems. Pump issues i guess.
Not a very talkative guy. Don't know why he hasn't sold any yet, other than a bit pricey. I hate being the friggin guinea pig. So that's that story.
I mean how many hours would it take you to do up a set of heads? Quite a few I bet.
I like this thread. IronMike I really think you should bite the bullet and fit the BPE heads and see the difference. I think Hughes stuff is inflated and over advertised for what they are, no offence to them
Hell I'd buy them if the guy even SOUNDED confident about them. Didn't get that warm fuzzy feeling....I'm sure he would if you sponsored him. And he could get them with out a long wait.
I'd like to see independent flow tests on those heads as well.
"Not sure about 3/8 pushrods", 3 more percent for credit card...
He said I would be the first pair sold. No way, man. Not for 2200 bucks plus.there must be some people with BPE heads, did he say if any are out there?, Brett Miller must have a pair. back in 1991 I was talking to Indy, and asked when are you going to make some small mopar heads, he said send me $5000 and we will do it
So big change of plans after 2 phone calls. First call was that the rocker I sent to Dave Hughes didn't really spec out to 1.6. Ahhh... not even 1.5. I friggin knew it! I know how to measure lift at the damn valve. 16 new ones, each one checked out, are on the way. Good on Hughes!
Also spent 90 minutes on the phone with Tim at Bullet. 90 minutes. Gave him flow numbers, dyno numbers, everything. When he plugged in my flow numbers on some software, it all jive pretty much exactly like my dyno sheets. Not really what we all expected.
To shorten up the story, my exhaust flow is way too efficient for the corresponding intake flow. He used the same term someone did on this thread. "That thing can't clear it's throat". Something about 75 percent is where you want to be, intake vs exhaust. I'm way over.
So before I start epoxying anything. Send the cam back. It's going to be split duration, alright. But split the other way. I think he said 269/255. Seen it before, done this before, so we shall see.
So really.....when you look at things, I had a 560 horse motor, not 400, or even 450, but 560,,, that had way less lift than thought, and had a cam ground for heads that I didn't really have. I have a feeling this is all gonna work out. Just a hunch. Got nothing to lose except time.
I would love to buy them for Ironmike to trial as im close to pulling the trigger on some but im on the other side of the world so its a bit trickyI'm sure he would if you sponsored him. And he could get them with out a long wait.
LSA stays where it is, I guess. Don't know how the rockers got out the door. Dave wouldn't admit what was wrong when we talked, he just said I'm sending you 16 that I personally spent half a day checking. It was later when I called back, that his guy told me they were NOT mis marked, as far as ratio, they were not EVEN 1.5.Where is he going to put the LSA?
The 75% rule is ok for a start, but good heads are more like 60-65% exhaust/intake flow. And I wouldn't say they exhaust is that good, it's that the intake is not that great.
How the hell did Dave let rockers get out the door with the wrong ratio? He blows his own horn about his ratios being correct. You have to check everything. That's one reason why it costs so much to do this. You have to verify everything.
Keep us posted. Hopefully some learn from this episode about checking and rechecking and double rechecking.
