joec
maybe its just the picture but that intake port looks pretty clean(as in not much reversion)!
View attachment 1715030154 View attachment 1715030155 View attachment 1715030156 View attachment 1715030157 View attachment 1715030158 View attachment 1715030159 View attachment 1715030160 Took the heads to my machinist/dyno guy, since he's never seen the inside before. Basically he agreed that the SS was murdered beyond REASONABLE repair. We put my cam on his Cam Doctor machine and it checked out dead nuts on the money. He doesn't believe there's much reversion. We did 13 pulls and the intake runners are pretty clean.
Showed him the flow numbers and said throw that away. Yea, they look lousy low and mid lift, but don't live or die on numbers.
So... what he hated that CAN be fixed is how they over-cut the back and sides of the port. Light bulb shaped. My best option is to ditch the heads and buy a pair from Rod Bloomer.
My other option is to epoxy the back, sides and part of the floor to give the air a straight shot into the cylinder. He felt there has to be huge turbulence the way they are now.
Showed me some AFR, Dart, and TrickFlow heads. No lightbulb shaped ports in those
He used modeling clay to give me a sort of "template" as to how to shape them, and gave me the part number for the epoxy they use.
I think I posted 4 pics as they are and 3 of how he wants me to change them. keep in mind, the 3 pics are done with clay and rough but I get the idea.
Also said keep the cam. It is ground correctly and SHOULD make more power. Just changing cams "will not fix this".
so.....at this point, I'm going to goop 'em all up, get them even and smoothed and give it a shot. If that doesn't help, i guess I'm selling some guns and buying a pair of BPE's.
A mentor of mine was one of those messing (and winning) with the 351C heads. Iron inserts welded in and the port was reshaped.
Iron - For what it's worth I agree with your guy.
Hey Mike, Where can you get this material?Epoxy is called Goodson 2 part cylinder head epoxy. Mixes to consistency of soft clay.
Geez, if only I knew
I can remember that fix.. that short side exh. hump was the water jacket! Then there were the steel flanges that bolted between the head and the exhaust flange that had 'tongues' that stuck into the exh. ports to 'fill' this area.Back in the day, the one and only on i saw hand half of the exh port cut off then a alu piece was bolted on to fix the exh problem.
Was told that it work GREAT! but was a ***** to keep coolant leak out of the equation.
I am guessing that they use just one bit to do all that milling in that area, and that they can't get it any closer to the guide in that area. A different, smaller bit would be needed, runnig slowly in that area, and that is a tool change (if it is not a multi-bit head) and costs time and $$.You can't tell, but that unmachined black area is a good .175 taller than the surrounding port. In his words, just a mess....
Geez, if only I knew.View attachment 1715030245
I got the pinch real thin on a few ports, to where you could flex it with your finger, used this and still holding, cast iron on the street.Hey Mike, Where can you get this material?
Link?
Simply google goodson, they sell machine shop supplies, fairly quick turn-around.................Hey Mike, Where can you get this material?
Link?
Epoxy is called Goodson 2 part cylinder head epoxy. Mixes to consistency of soft clay. He told me a wet finger will do perfect. Might not even need sandpaper (I will). You have 15 minutes to work the stuff. Ordered it today.
It's like the "prostock" theory that I heard go around about 1990, basically the floor was a ramp down the backside of the valve at whatever max lift was accomplished. I don'tHere's a link to study and a crude hand drawn picture I whipped up (it is exaggerated for illustration but not much). Just going to leave this here and I'm out. J.Rob
How Kaase created a cylinder head for modern street-strip use | Moore Good Ink
I just called them. 1 800 533 8010. 37 bucks for a can. Called late yesterday, UPS says it'll be here tomorrow.Hey Mike, Where can you get this material?
Link?
I'm off Thursday, too. God help me, I'm goin' at it.
Ya know.....I thought about selling them to a guy who's just looking to build a nice 450-500 horse motor, but really, I mean really, where could I find some good CNC'd heads right now?
Nowhere.
I decided if it could happen, I'd just buy a good pair and call it a lesson learned. Far as I know, nobody has them "on the shelf" and ready to go. I don't have time to order up a pair from someone.
