yellow rose
Overnight Sensation
So does the bench calibrate itself? I don't know that's why I'm asking.
You have to have a calibration plate to verify the bench has no leaks.
The correction is done in the software.
So the computer has its own weather station?
OK thanks. Sorry to pull the thread off track. I do have lots more flow bench questions. Maybe I'll start a new thread.
I get the issue. I'm absolutely not doubting what Dave said about no one buying them. I did my own heads with 2.02 valves and everyone said I was crazy. It's all about marketing. Surely a 2.08 valve will kick the hell out of a 2.02 valve. In advertising.
BTW, I've been using seats steeper than 45 since about 2000. That's how OLD the technology is. It's hard to do it on a street strip deal because...
A) If you go from a 45 to a 50* seat it makes the margin thin, quick. Not if you cut down a larger valve or go custom.
2) It takes a different shape valve to make the steeper seat work correctly, and guys don't want to buy anything that isn't interns normal. You would think and yet tulip valves are only considered normal with the Hemis
B) The steeper the seat, changes the way you face the valve. You lost me here.
1) There are other reasons but I'm sure you know them. Nope see above.
BTW, you can make the back cut as wide as you want it, it doesn't make a difference. As long as it runs up to the seat is all that matters and it's still a bad idea in most cases.Seriously not understanding this.[/QUOTE]
Most of your posts offer nothing to help OP all you do is regurgitate something you've heard or read somewhere before, oh and you like to name drop as well. I don't care really about anything online as I'm receiving no compensation whatsoever however-when I read downright false/misleading and downright dangerous advice I cannot sit idly by. Oh and FABO and its ads are starting to piss me off so bad I'm finding myself not wanting to come here as much. J.Rob
Who do I name drop?
Most guys don't want to buy custom valves or cut down a bigger valve. That was MY point.
Bullshit. Many people don't use nailhead valves in everything. Ive got 4 cylinder stuff out there with 50 and 55* seats and ALL of them get tulip valves.
I'm not getting paid to educate you on how to do steeper than 45* valve jobs so you can figure that one out. The steeper the seat, the more the valve wants to wedge in the head.
I'll say it again, I don't like back cuts on much of anything, but the width is not important. The angle of it is (most guys love a big back cut because it looks good on the flow bench) not important, as long as the back cut butts against the seat on the valve. That should be easy to understand.
I offered to flow his head for FREE. And I would not have just flowed it at one pressure and sent it back. I also offered him a cam I've used and know what it does. Did you want me to drive across the country and pick the heads up? He would have learned more from my flowing the heads that just paying someone to test at one pressure.
What do I regurgitate? If I was regurgitating I'd agree with all the goofy **** you do, like opening the LSA when mid RPM power is down. If he has a reversion problem that is about 1800-2000 RPM no cam, not even the wide LSA will fix it.
Come on dude, get over yourself.
You're a GURU of more than just engines--you just fixed me, I'm over myself. Thanks, J.Rob
Bingo!Yeah give him a call , after you tell him his heads don't flow he will insult you and your flow bench guy. J.Rob
Couple pics of the ports. Don't know if pictures "do them justice", but thought I'd throw them out there. There is no "hump" where the CNC stops. Not that I can see or feel, anyhow.
Take a look at that dirty intake valve after 13 pulls.
So just wondering......can a smaller valve be installed once a 2.08 seat has been cut? Just wondering.View attachment 1715029983 View attachment 1715029984 View attachment 1715029985 View attachment 1715029986
If that is the only dirty valve from a running engine, I'd look for a damaged/work valve seal or worn piston rings or a bad intake to head gasket seal.that dirty valve was caused by reversion am I correct?
I like that one a lot more! In the SS, in the transition to the chamber and the bowl as well.Just for comparison and because I found the pic... the SS of the new BPE heads.
I have never heard of BPE HEAD for a chry small block.
