65 Mopar
66 Ficks
What the heck could cause two different Pistons to have broken rings??
The bearing has had a piece of metal in it that caused that deep groove, but they are not worn all that much.
Does the crank look ok?
Thank you!!This will explain it.
Chrysler Electronic Ignition
ThanksBlue box is a mopar performance voltage regulator P3690732
I thought the Orange box ran a dual ballast; Oneside for supply voltage to the ECU, and the otherside to the coil. Pic 106-B shows a single ballast
Are you running a 4-pin ECU then?No my 69 Dart with the USA made Orange ECU runs a single ballast.
