65 Mopar
66 Ficks
Forget the headers and private message Treblig. He sources those manifolds. http://www.forabodiesonly.com/mopar/conversations/add?to=Treblig
Msg sent
View attachment 1714952024 This picture is for Treblig to see if I can use the manifold he has with my oil filter being there. It's right under nbr 8 cylinder..
Did you message him???
Right now I there is no stall, its stock.
I have that purple cam with the .484 lift that was discussed earlier. 355 gears in the back w/ a sure grip, 727 trans
The TCI P/N 141200 really seems to fit the bill for me. Direct connection told me that cam would be best with a 3000 stall but would also work with a 2500. I need the drivability..
havent heard much good about tci lately, with that cam i used hughes 3000, inretrospect i shoulda went custom, it did the job though
Now you may want to consider a set of aluminum heads? Compare the cost of the two.
