SSG_Karg
Enhanced member
Ok. So I’m at the point in this build that I need to order a camshaft. I’ve already reached out to a few cam grinders for their recommendations and have heard back from Jones, Crower, and Oregon. Their respective numbers are pretty close so I kinda know where I wanna be but I thought I’d like to put it out to you all to see what your recommendations are.
For a little background on the application, this is a street/strip build with 75% street and 25%strip. Absolutely zero freeway driving.
72 Duster approx. 3300#s(not verified), 2.66 first gear A833, 3.91 rear, 28” tire.
422” smallblock with long valve W2 race heads (flow stalls at 266cfm @ .550”) 2.08/1.60 valves, 1.5 iron rockers, dual plane Mopar intake, 950 Holley HP, 10.75-1 compression.
I’m looking for a solid roller with a sweet spot of about 2500-6500 rpm that will not need ridiculous amounts of spring pressure. Idle quality is not important, vacuum not important.
Ok guys, give me your thoughts/recommendations/warnings.
