My 422 smallblock build
Why would wheel diameter have anything to do with hydraulic or solid? I totally agree that the bigger the wheel the better but why would it be less desirable on a solid application. The wheel is going to make the same amount of revolutions per camshaft rotation regardless if it’s hydraulic or solid.
Actually there are a couple of reasons. As I've posted before, the de facto wheel diameter is .750 because that is all you can fit in an .842 bore.
Chrysler's use a bigger diameter core than Chevrolet. That means for the same lift, the Chrylser will have a higher wheel speed. Wheel speed can be critical as RPM goes up.
If the lobe is ground for a specific wheel diameter, changes either larger or smaller changes the cam timing.
A solid roller wheel changes speed with every lash cycle. It slows down as it gains lash and actually skids to gain speed as it wheel gets on the lash ramp. A hydraulic roller wheel never gets lash so the wheel does not speed up and slow down.
The smaller the wheel, the smaller the shaft axle where the needles ride. Again, it's a speed thing.
As I've said, there are many factors that go along with wheel speed like cam materiel, lobe design, the materiel of the wheel and a ton of other things like pushrod stiffness (or lack thereof), lifter to bore clearance, lash and lash ramp design and more I'm not thinking of that change the resonance frequency of not only the lifter but the entire valve train. Some call it the harmonic wave length.
At any rate, if you run the lifter into a frequency the wheel on the lifter will mimic a tuning fork. It will literally vibrate. This not only fails the wheel and axle but it will break the rivets holding the link bars on the lifter, the adjuster lock nuts will back off no matter how much torque you give them and many other anomalies that break parts that shouldn't break and it's not the parts fault, it the lifter in a reasonance frequency.
"Chrysler's use a bigger diameter core than Chevrolet. That means for the same lift, the Chrylser will have a higher wheel speed."
you thinking rpm with the larger wheel YR?
AFIK all retrofit hr use the .700 wheel
What's oem mopar hr?
you can fit a .815-820 in a.904 lifter bore oo big get too narrow
or bore to .937 to clean up the lifter bores
with keyed lifters even larger
I've used isky's
I've used isky's
On the same cam the smaller the roller the higher the roller rpm.
The junk Comp retro fit hydraulic rollers that unfortunately are in my 340 have a .810 diameter roller.
the larger core means that it is a longer distance around the lobe
the larger wheel rpms slower
i did bot know comp had .810 roller in retrofit lifters
anyone else run them?
AAFIK johnson made all the retrofit lifters
512-- is yours a roller block with stock replacement lifters?
I run comp solid roller lifters with the larger wheel, don't think they are considered a "retrofit" lifter though. They also have the tie bar on the inside instead of the cylinder side.
On the wheel diameter/speed thing I use a boat trailer tire to explain. A trailer with a 8" wheel and say a 15" tall tire will have a greater bearing speed than a 20" tall tire on a 13" wheel. In a mile they both travel the same distance but the smaller tire has to make more revolutions.
On the wheel diameter/speed thing is to use a boat trailer tire to explain. A trailer with a 8" wheel and say a 15" tall tire will have a greater bearing speed than a 20" tall tire on a 13" wheel. In a mile they both travel the same distance but the smaller tire has to make more revolutions.
Perfect analogy. And if the tire speed goes up, so does the bearing speed.
Same thing happens with a lifter.
It’s what’s in my 372”
The comp solid body roller lifter with the .800 or .810 roller. I had a buddy run these for over a decade in his drag car, 2 different engines. I figured I’d try them in a street car?
He didn’t block anything, ran good oil pressure, no issues. Same thing on the next engine, a 360. He had a 340 in it for around 10 years. Raced it at least twice a week.
The weird part was the 340 would out 60’ foot and mph the 360 with a best 1/8 time of 6:13 and the 360 ran a 6:11 best, same heads and cam. 2600 pound Demon
I do have oil going to mine, and didn’t block anything. Though I checked oil pressure as I rolled the engine over, and no losses.
The next engine I’m putting together, will be blocked off, and rely on splash oiling. The x block I bought recently.
I’ll see how these lifters hold up. You guys have relayed some complaints about these lifters, or the other models Comp offers?
My block is a all stock 1969 340 LA, no oiling mods
You should will be OK with the solid rollers from Comp.
Just stay away from the hydraulic rollers, never again for me.
Washed the block and got a quick coat of paint on her and got the freeze plugs beat in.
Layed the crank in and checked main bearing clearance with Plastigauge. All measured between .0015 - .002”. Crank endplay measured .0025”. The crank is a forged piece from BPE with a 4” stroke and 2.10 rod journal. The rotating assembly was internally balanced by Courson Racing Engines in Emlenton, PA to 1852 grams.
If you use ARP bolts on the main you will have to clearnce the pump where it sits above the bolt. I had my main seal leak 3 times before we found this. The 3rd time through we found it because the oil pump gasket blew into 2 pieces (half of which was sitting in the bottom of the pan) . Looking back at my build thread, I see that somebody warned me about this but I didn't catch it.
Thanks for the heads up but I just used a factory main bolt under the oil pump body.
What is the Comp solid roller solid body part number?
828-2 is the one that’s been around for years. No mods to the oiling system usually not needed with this lifter, unless the lifter bores are worn.
Still have to check it, as one lifter puked oil at max lift, and I was able to move it to another cylinder and it was fine.
70-80 pounds of oil pressure, and no losses.
A ton of grinding in the lifter valley for clearance on the guide bars.
I should check them in my x block, as I’m not looking forward to a dozen hours of hand grinding.
I'm running a fairly mild cam (by mech roller standards) 242/242 @ .050, .571 lift.
I'm still a little ways away from trying them (as seen below), but if by chance I get finished first I'll be sure to post back.
Anyways, good thread, I'll be watching.
Do you have a thread going on for your build?
My cam will be very comparable.
I don't have a build thread, it started out as an EFI swap in the fall, and step by step ended up where I'm at now.
Dwayne Porter spec'd out the cam for me to work with my efi system, it was originally for the 360 that was in the car, but I found some pitting on one cylinder wall and when it didn't hone out I decided if I was going up to .040 over I would build it as a 408.
So I had a little setback during assembly. It was one step forward and two steps back this weekend.
During the initial mock-up of the rotating assembly I mistakenly thought I had enough clearance between the bottom of the cylinder bores and the connecting rod bolts. There was no contact anywhere but it was close. There was .070” clearance on one and a few were within .020”. I did some digging and found that K1 recommends .060-.080” for steel rods and .100” clearance for aluminum rods.
cb2dbf4c-5610-4aee-8922-71415bbf71c1-jpeg.1715484109
1917662f-5b2f-4bfa-b083-e7e433703f36-jpeg.1715484110
Soooo, long story short I broke it back down, notched the bores, washed it again, and reassembled. Now I have at least .075” clearance on every one.
b2697e87-b5dc-4558-be4f-8a9bae806b94-jpeg.1715484117
c678a91f-b97f-436f-b815-37881c9525aa-jpeg.1715484118
Gotta love it.
