I guess I don't get it? I don't see how a motor mount failure can do that unless the fan spacing is just too close to the radiator.
I've always run spool mounts and never had any of the issues y'all mention.
Don't wear a frown.. CHAIN IT DOWN!.
Out of all the old school crap I've tried and/or done the chain not only has worked seemingly very well, but gets tons of notoriety...
FYI scrap metal.. FREE....
Well my engine even being balanced to less than a half gram on all rotating parts shakes A LOT...
But I do have a 107 LSA cam with lots of over lap...
You can see it go tight against the mount when I stall it up a bit. I'm not sure where the movement comes from as I have frame ties and a 12 point cage. (And the one solid mount on drives side.)
What did you have some old rusty chain that was too long and hanging down on a broken motor mount?I'll try the solid driver side mount first, if it's too harsh I think I'll try a chain-strap.
When I first got my Duster it had a broken motor mount, I wrapped chain around the mount bracket and k-member which worked but it looked like sh*t.
Shouldn't need a lot of clearance. 1/2" to the core is cutting it close but should be OK. Fan tip to top tank is the other place to watch for - any slop in the clutch unit plus the forces on the blade are all encouraging them to go forward. With a '70 body, it should have enough room for the MP viscous clutch and the 5 blade fan on the aluminum pump. The damaged fan in the photo looks like its for an earlier tank. Check the verticle measurements - the slightly smaller diameter fan (like MP 5 blade unit) might be better fit.I forgot to mention the fan spacing wasn't good either. What actually caused the fan blade to bend was it hit the bottom edge of the upper tank before cutting into the core; there's a noticeable gash in the tank from where it hit, about 1/2" long. I have another factory viscous-drive fan but the clutch is too thick and hits the rad core; I'm going to swap the fan itself onto the current clutch which is still fine and add a washer or 2 on the back side to space it farther back just a hair.
Oh and the motor mount didn't technically "fail", the two biscuit halves are still stuck together but about half of the rubber has torn away from the steel. So basically since getting the new engine in, every time I romped on it the mount would tear a little more and let the engine move a little more over and over until this happened. I was dumb and should have checked it before it would have been so easy, I could feel a weird "thump" when getting on it hard which I now figured out was the engine falling back down on the k-frame. Oh well, 20/20 hindsight and all, once I get everything fixed and back together I am definitely going to test out the new mount with the hood open and load the engine up against the converter to watch how much it moves.
SO what actual fan/radiator clearance did you have. MP recommends 3/4". Would that have even been enough?I forgot to mention the fan spacing wasn't good either......
