j par
Well-hung Member
A little 90 weight should take up the slack....A little of the wigglin you saw was the whole head moving. I think if the guides were tighter I might have been border line nervous.
I got to tell you right up to the last couple of hours I want to order a manifold just in case I ever got to something I wanted to do the Magnum swap on which is something I've always wanted to do ever since I knew it could be done...when I say I wing it, no plan, I'm sporadic, this is what I mean. -- Plan was to buy ProMaxx. Couldn't pass up 40% off so I buy SM. Wait, 40% off??? why not big block heads as well, don't use 'em I'll sell 'em for profit in May. Wait!! Why not a couple of intakes for magnum heads and LA, never know what I may decide to put a magnum in. Now, you can sit back and wait for the next "Wait"! LOL
I remember in high school auto shop the theory was the knurling allowed more oil in between and would counteract the lack of material... Just spitballing for conversation sake of course...Yeah, I thought I saw that. I just wasn't sure. I've run some loose guides before. I've done a LOT of reading about knurling too. Enough to change my mind about it. I think it's beneficial......AS LONG AS you run "some type of" roller tipped rocker. I say that because the knurling does remove some surface area and as a result, they will wear sooner, unless a roller rocker is implemented. As long as you run rollers, I believe they will last virtually forever at that point, because that's about the only benefit rollers give, IMO. They just about completely remove the side loading and wear from valve stems and guides. Well worth their expense, IMO.
Thanks again for this write up. It's a goodun.
As far as valve jobs some of you guys are spoiled. I got away from stones years ago and moved to Neway valve seat cutters but I’m limited to your basic 60-45-30-15-10 valve angles instead of you custom angles. I almost had that ability 6 years ago when a friend closing his speed shop offered me his mill and all attachments for 1200.00. If my son had any interest in doing heads I would have bought it but he doesn’t so I didn’t. I think my heads do ok with old school technology so I’m stuck there. For guys that have never seen Neway cutters here’s a link. I bought mine in bits and pieces on eBay over the years
I'm a knurling hater.
Cheap way to tighten up a valve stem and the best way to build up carbon on the inside of the intake valve.
I would run a loose, new, bronze valve guide all day lone over knurling it! lets just give the guide a oil groove for the oil to run down and drip on that hot intake valve.
If my grannys 318 Cordoba, that she drive 300 mile a year in, need a head rebuild, i would consider Knurling.
And the same statement hold true for a slightly loose, new, bronze guide.No way oil is drooling down the valve with good valve seals. Ain't happenin.
and or Valve StemAny guide for that matter......but rarely will you see a GOOD seal on a worn out guide. lol
yes, running the valve job provided. If I was to pay my machine shop, I'd have put my own hardware in the heads. To me, at least, the only purpose to buy loaded heads is save the $$$ and run the provided hardware - after a home inspection.Thanks a lot for the video! I just read this whole thread and maybe I missed it but are you running the valve job as is? Are you going to lap them in even though they seal?
Cley
Neway Valve Seat Cutting System
That's how it is.… I couldn't get 150 for a LA 318 2bbl here. But we can't find your trucks... LOLI could probably sell this running 318 out of this truck for $350 which would have been a hundred and fifty for the manifold and 200 for a junkyard Magnum... But to do all that work just to give it away...
CHEESEBURGER...Dang for that money I'd have snatched that mill up in a New York second.
It's crazy how important not only the angles are, but the worth of the angles.
And it depends on the bowl too. On 45 degree stuff for MoPar OE junk I like a 4 angle cut with the bottom cut a full .100 wide. I can't remember the angles at the moment, but IIRC the rest of the angles are all at least .060 wide if not .080.
On the 50 degree stuff the bottom cut isn't as wide...maybe .080ish IIRC.
It all makes a big difference not only in flow through the port, but how well the port flows backwards and even how well they flow at different test pressures.
To those that have bought the B3 rocker correction kit: what does it cost? Not seeing that in any posts. Very elusive!
Holy smokes! 180 bucks!!Searching a while back I found a price of $180, could have gone up in the mean time.
