CMcAllister
Title says "My take on the oiling system crossover tube for the small block". I'm assuming high RPM small blocks. That's my take on the subject.
The crossover tube is crap. The left side galley should be dry. The only reason for oil there is hydraulic lifters or oil through pushrods and I wouldn't use either of those either. Not with OE style rocker shafts. However, a direct oil auxiliary line putting oil into the front of the right galley is a good idea. This can be plumbed to the passages at the back of the block, the filter adapter or wherever and run under the intake or externally to the front of the block.
I think he’s got that......
Your opinion does not even fit into the subject of this thread. It's very hard to run the left side empty when you're trying to lube and fill the hydraulic lifters.
AKA = Drivers sideThe left side galley should be dry.
high rev with hydraulic lifters ? what are the rpm parameters, I would think the stock system would support 6500 with the right valve spring, lifter and oil capacity.According to the Chrysler engineer that designed this and implemented it, the crossover is to be used only for high reving sb's with hydraulic lifters.
I agree, for me anything above 6500 gets a solid. I spin low deck big blocks 7500 with solid flat tappets, but mostly 6800.7200 and up. Never used a hydraulic in anything like that. Always solid rollers. Any mods I've ever done (or not) were for the purpose of keeping oil on the crank at high RPMs to avoid starving the bearings. That is the priority.
Why would I put oil in the left galley when I run a solid cam, bush the lifter bores and run a -6 feed line from the rear of the block to the very front of the right galley, effectively feeding it from both ends to correct the effects of oil having to run the gauntlet from the rear to the front of the block? Call it a crossover, I'm just feeding the front of the right galley, keeping ALL the oil in the side that matters, rather than taking any detours.
In the MoPar engines book, they say 5500 rpm’s for regular cars. I read somewhere, IIRC, HP pumps were suggested for up to 6200/6300 rpm. No other modifications were mentioned as I remember it. The conservative rpm ceiling was due to irregular or non standardized machining of the oil feed holes throughout the block.high rev with hydraulic lifters ? what are the rpm parameters, I would think the stock system would support 6500 with the right valve spring, lifter and oil capacity.
Seems obvious... to reduce the oil velocity in the back portion of the right side gallery and solve that particular issue.Why are you double feeding the right side?
Well, be it as it may, I never had a problem at 6500. Do these roundy guys exceed that with hyd. cams?should but it doesn't
problem is where oil goes from left to right and trying to feed a main at the same time
put a really good pressure gauge at the left rear, left front, right front
I've heard that it's been done but not by me but roundy round builder went to front oiling
I have on occasion, we went to a track we had never been to, had a bit too much rear gear, and ran about 100 laps one night, tach recall said 7200 after the feature.Well, be it as it may, I never had a problem at 6500. Do these roundy guys exceed that with hyd. cams?
WOW! Woo-Wee! That’s a lotta rpm over and over again. What was the cams duration of you remember? Not a street grind I’d imagine! LOLI have on occasion, we went to a track we had never been to, had a bit too much rear gear, and ran about 100 laps one night, tach recall said 7200 after the feature.
No, definitely not a street grind! It was a lift rule limited cam, I think .420 if I remember correctly, and duration was high 240s @.050, sorta like a super stock "cheater" cam. Extreamly fast ramps, and was pretty hard on valve springs, but it did make power. Not at 7200 though!WOW! Woo-Wee! That’s a lotta rpm over and over again. What was the cams duration of you remember? Not a street grind I’d imagine! LOL
I also never disagreed with you on the oil timing issue.Mostly I keep you on ignore because you ain't worth the time. If you go find the thread Duane started I think it's in there. I also wrote it out AGAIN. It ain't that hard.
