1973dusterkid
Watch This
Well I cleaned up around it and did not see any leaks around he dip stick of the speedo cable. When I get back from school tomorrow I will check again. It is leaking from the B&M shifter bracket. It is leaking from the bolt heads on the shifter .It is also leaking from the lip of the pan on the pass side front and pass side side.
