crazy 340
For your viewing pleasure.
do they oïl via the push rod or the shaft???
Push rod oiling. Use AMC style lifters if Hyd flat tappet or solid roller any push rod style will work. Most manufactures offer this right off the bat.
Very nice. What's the part number for 1.6's?For your viewing pleasure.
Sweet. I don't need 1.9 but 1.7 would be nice. How much adjustment on the cup adjuster before oiling is a problem?#74192F is the part number with any ratio you want 1.3-1.9 ratio. $1566.38
Great. Assuming this weekend goes well, I'll be ordering a set next week.Since these are Ball and Ball style of pushrods we set them up with no more than two turn from bottoming out on the rockers. Also I made these so we can use over the counter style of push rods and we have them offered in 0.050" increments. So that is not a problem.
Flow numbers are right on Edelbrock's site. We made 630 on pump gas with a hydraulic roller cam. I've heard that lots of high compression solid roller engines have gone 700+ with these heads.Flow numbers? I can't find anything solid on these heads fully ported numbers.
Are there any of these heads running out there yet?
I'm gunna pull the trigger on a Ritter block tomorrow and will be using these heads most likely on a new build or if need be w8's or 9's
Any info would be appreciated.
I'm not saying that they can't be improved upon, I'm saying that the flow numbers for them OOTB is on the Edelbrock site. I used them as-is for the build I did. Unless it's an all race build, I don't see how you could justify the added expense of having them ported.I thought there may be more HP in these heads with someone else's hands is on them after buying them...
So these heads are Maxx flow your gunna get straight out of the box? I find that hard to believe. Hmmm
Thanks for the links
In the thread on Moparts Allen Sherman said he left them as is and only changed the valve seats to his liking. That sounded like he didn't feel the need for any more porting.So these heads are Maxx flow your gunna get straight out of the box? I find that hard to believe. Hmmm
Yea, that's what I read. I didn't see any flow numbers other than Edelbrocks. Considering how how many people out there having flow there head and not come up with there numbers that they did, I can only wonder this time around.In the thread on Moparts Allen Sherman said he left them as is and only changed the valve seats to his liking. That sounded like he didn't feel the need for any more porting.
345@.800 and 350@.900 but flow numbers aren't the end all be all factor of good cylinder heads.I thought I saw 380 cfm at .800 lift...
I bought the 61739's. I hsd to mill them for pushrod clearance because of the 48 degree application and had to mill them for the Crower rockers.Thanks for the info!
In what configuration did you buy your heads?
They were top notch as well. I measured actual lift at the retainer and I was within .001 of theoretical lift with a checking spring. Nice work!I made those rockers. Enjoy.
