I haven't flipped thru Boobtube comments yet, but is anyone calling him out on this foolishness?
a few people... but most are like OHHHH AHH!!! the great and powerful Oz has spoken!I haven't flipped thru Boobtube comments yet, but is anyone calling him out on this foolishness?
This right here is my single biggest point of contention! He has no idea what the curve looks like, or what the Rev limit is set at. He revs it to XXXX rpm and reads the light (when he uses it) and declares it has 28 degrees? What if I made the curve to come in more like 3500rpm? I'm pretty sure he has 10 or more degrees timing than he thinks, which is why it gained nothing on the race fuel, and also why the best pull was when he backed it to "26". Wouldn't you back it up further to see if it kept picking up? That's how I test anyways. J.RobEspecially since nick STILL has no idea what the timing curve looks like
AHH!!! I was wondering why it picked up down at 26.. my brain was like.. ummm 26? how... and yeah.. i woulda gone lower til it leveled out to get the data.This right here is my single biggest point of contention! He has no idea what the curve looks like, or what the Rev limit is set at. He revs it to XXXX rpm and reads the light (when he uses it) and declares it has 28 degrees? What if I made the curve to come in more like 3500rpm? I'm pretty sure he has 10 or more degrees timing than he thinks, which is why it gained nothing on the race fuel, and also why the best pull was when he backed it to "26". Wouldn't you back it up further to see if it kept picking up? That's how I test anyways. J.Rob
I tell my customers that a timing number is only half the information you need the other half is at what rpm the timing is taken at.This right here is my single biggest point of contention! He has no idea what the curve looks like, or what the Rev limit is set at. He revs it to XXXX rpm and reads the light (when he uses it) and declares it has 28 degrees? What if I made the curve to come in more like 3500rpm? I'm pretty sure he has 10 or more degrees timing than he thinks, which is why it gained nothing on the race fuel, and also why the best pull was when he backed it to "26". Wouldn't you back it up further to see if it kept picking up? That's how I test anyways. J.Rob
I was hoping he'd just plug in his MSD 6al box and then he would know without a doubt whatever the locked out timing was AND he'd have control over the Rev limit. Furthermore with the RBRE/T&D rocker system and the Isky Toolroom springs and TS retainers, the valvetrain is likely good for well over 7000 rpm. But it's stated numerous times "Might be valvefloat". How about taking the valvecovers off to check the lash and inspect the valvetrain, BEFORE firing it !? One look at that caliber of hardware and any seasoned pro would have a hard time believing valvefloat is the culprit. J.RobI tell my customers that a timing number is only half the information you need the other half is at what rpm the timing is taken at.
Nick is internet famous... that makes him the better choice for most people.I can't understand why he took the engine to nick instead of jesse , it's not like you are far away , what two three hours . And whats even crazier not even a phone call .
I'm 1.5 hrs from Laval and Nick has been to my shop once before. J.RobI can't understand why he took the engine to nick instead of jesse , it's not like you are far away , what two three hours . And whats even crazier not even a phone call .
I think this may even turn into a whole series. He's already talking about replacing the head gaskets....so why not go all the way? If the customers game that is. J.RobI can't believe they are making a part 3.. and in the preview... he offers up another dual quad intake.. after shitting on the first one.
AHH! i forgot bout the gaskets.... just curious.. why would head gaskets start leaking just from sitting? Also.. i know i'm paranoid and overthink but i wouldn't have turned it over again cause i woulda been worried bout water leaking into a cyl and we know how much water likes to compressI think this may even turn into a whole series. He's already talking about replacing the head gaskets....so why not go all the way? If the customers game that is. J.Rob
I can't believe the dipstick wasn't even pulled to check. J.RobAHH! i forgot bout the gaskets.... just curious.. why would head gaskets start leaking just from sitting? Also.. i know i'm paranoid and overthink but i wouldn't have turned it over again cause i woulda been worried bout water leaking into a cyl and we know how much water likes to compress
I had thought of that.. but i don't think hemi heads pass water... at least in that intake they wouldn't...I'm willing to bet its the intake that he put on is leaking not the head gaskets . Why weren't the head gaskets leaking last test , maybe they were but i missed it ?
yes you are right the water does not go through the intake I'm not that familar with Hemi's but it's not hard to tell with a quick look .I had thought of that.. but i don't think hemi heads pass water... at least in that intake they wouldn't...
P.S. although the bolts might go into the water jackets.. no idea.. i have slight hemi fever but could never justify it
Seasoned pro is the missing part here. It’s amazing to me the valve covers never came off to check lash, zero carb adjustments, and absofuckinlutely no idea what curve is in the programable box. Those three things should have happened before there was even an attempt to fire that poor thing. I read some of the comments on the video, I just shake my head at the unbelievably ignorant *** hats praising Nick and his “efforts”. I said it before and I’ll say it again, what a **** show. Oh and I forgot, NOT ONE FUCKIN SPARK PLUG READ!One look at that caliber of hardware and any seasoned pro would have a hard time believing valvefloat is the culprit. J.Rob
On mine I use my phone with free MSD App. But yes MSD has downloadable software for a laptop and you just plug in to it.I am curious... i have never used a laptop to program MSD stuffs... is the software readily available? special cable needed to read the box?
wow.. that's cool you can do it from a phone though.. I will never trust MSD (for the street) but that's a cool optionOn mine I use my phone with free MSD App. But yes MSD has downloadable software for a laptop and you just plug in to it.
I’ve raced thousands and thousands of miles through the Mexican desert (read; dangerous) and the ONLY box I want on board our truck is the MSD 6. We have two boxes for redundancy and in 15 years of racing, never used the spare.I will never trust MSD
you are lucky...i have had to rescue soo many friends in the past cause of msd parts.. BUT that was also a long time ago... I will never have anything that needs a better ignition.. so moot pointI’ve raced thousands and thousands of miles through the Mexican desert (read; dangerous) and the ONLY box I want on board our truck is the MSD 6. We have two boxes for redundancy and in 15 years of racing, never used the spare.
Most of the problems associated with ignition, are user induced. Wiring being the main culprit 99% of the time. I mean we did just see Nick crimp a battery cable with freakin Vice grips.you are lucky...i have had to rescue soo many friends in the past cause of msd parts.. BUT that was also a long time ago... I will never have anything that needs a better ignition.. so moot point
