Old Yeller
Listen to this guy...^^^^
He was a little different in the Water Boy! Coach Klein....
And by the way, if I run the edelbrocks, I will get with you. Thanks for the offer.
Nothing on this motor has to be permanent, I like working on them...
One cool thing about the sweptlines is that the hood opens more than 90 degrees, so you can pull the motor and trans out together without taking the hood off.
Not only that, but half your fenders lift up with the hood, leaving a nice foot and a half work bench :)
cups spill to easy on that inner fenders , to wavy for liquids . i park the tools n parts on those . but they get dusty before i use them again , after all its not a chevy you got to fix all the time , lol . well my 60 is a low budget build using just used parts from other builds and swap meet buys , so far just some stuff hanging out and my fab ideas .
just an idea , this machine is just a driver . not sure of the mounting yet . frame mounted filter at the rubber hose and its 1/2 to the tank .
oh famous bob , so far nhra has not had any issues with my builds . and braided rubber hose lines are for show not for me . i'll do teflon with s braiding .
I have to ask, do you belong to the plumbers union. I like the work you did on the fuel lines. :thumbsup:
I understood you couldn’t use copper with gasoline? Have I been misinformed?
You don’t use copper on vehicle. It work hardens and will split at the seam. It will also split at the compression fitting.
BTDT and damn near lost a car over it. It’s for structural plumbing, not automotive use.
Ok that’s what I thought, in the previous pictures it looks a lot like copper?
I have a factory 75 Bayliner boat that has copper fuel lines. Factory
Wow. My fat arse ain’t getting aboard that thing. I can swim but I’m not swimming that far. Unless we are just 10 yards offshore drinking beer (which I don’t drink but I watch others do it, and hold their beers when the situation calls for it).
well the only piece thats hard copper is that manifold and that can be swapped out , its still in process , and sometimes everything get reworked . and as i said this thing is just used stuff hanging out at my shop .
The only place you would be is at the end of the rope attached to a tube being dragged over the wakes at 45 mph. lol
I use copper line for my exhaust evac PCV so the rubber hose doesn't get hot and collapse...
That’s ok. If it fails it’s just an air leak. If a fuel line ruptures it’s not a fun thing.
When I bought my race car it had copper tubing for fuel line. I changed the fuel tank (for the life of me I couldn’t tell you why I changed it...IIRC I didn’t like that it was round and if it wasn’t full the fuel outlets were uncovered at the hit...that’s going off my memory from 1984 so take that for what it’s worth) and I needed to move the fuel lines over about an inch because I relocated the fuel pumps too. I barely move the tube and it split. So I cut it off and it split when I cut it.
That’s when I knew it was not good. In fact, the entire system was rotten and would split if you moved it. Had I continued to use it I have no doubt it would have sprung a leak.
Don't worry Sam they'll circle back to your truck sooner than later LOL...
No problem... if I have to, I'll start a new thread like 318WR does.....!!!
Its all FUN! I will build what I can afford, trade for etc. The hunt for deals on parts is half of the fun for me. I just want to have it running this year, and hopefully make a few runs.
The main thing is I have a good foundation to start with. Heads, cams, intakes, headers can be swapped when I get what I really want.
