[ame="https://www.youtube.com/watch?v=mvIeLghwRDU"]1965 Barracuda - YouTube[/ame] Sorry about fuzzy pic...recorded w/I-phone 5s..dunno.. 318 Comp 268 xe Dodge Dakota manifolds w/2' flexible extenders <temporary>
[ame="https://www.youtube.com/watch?v=7dlmHyFM2FU"]1967 Dodge dart idle and revs ( 280h ) - YouTube[/ame] yes, i know the headers leak lol 1967 dodge dart Dodge 360 Build -1973 Dodge 360 block bored .30 over -Scat crank and rods -Keith Black pistons -11:1 Compression -Indy LA-X Cylinder Heads 2.02 intake and 1.625 exhaust valves -Comp Cams Magnum 280H camshaft .480 inches of lift 230/230 duration @50 -Comp Cams matched valve springs -Comp Cams Pro Magnum rocker arms -Weiand dual plane intake -Edelbrock 600 CFM Carburetor -Trick Flow SFI rated balancer
This sound Byte is "under load" [ame="https://www.youtube.com/watch?v=TcFWgjIB4gY"]1965 Plymouth Barracuda - YouTube[/ame]
just post a link to your car running with the engine & exhaust specs [ame="https://www.youtube.com/watch?v=dsJI17C5Qs4"]1967 dodge dart 280h comp cam idle - YouTube[/ame] Dodge 360 Build -1973 Dodge 360 block bored .30 over -Scat crank and rods -Keith Black pistons -11:1 Compression -Indy LA-X Cylinder Heads 2.02 intake and 1.625 exhaust valves -Comp Cams Magnum 280H camshaft .480 inches of lift 230/230 duration @50 -Comp Cams matched valve springs -Comp Cams Pro Magnum rocker arms -Weiand dual plane intake -Edelbrock 600 CFM Carburetor -Trick Flow SFI rated balancer 3in exhaust with dynomax ultraflo's
[ame="https://www.youtube.com/watch?v=P94HO27JbwE"]Dodge Dart Sport Flowmaster Super 40 Delta Flow. - YouTube[/ame]
452 CID RB 280/484 HYD CAM Hooker fender well 2" competition series 3"with X pipe and Flowmaster 44s dumped at axle [ame="https://www.youtube.com/watch?v=SQ8ByyYIWS8"]75 Plymouth Duster 452+6 Idle, Burnout, Return...3" X-Pipe, Flowmaster Mufflers - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=h_KDWD7oRYY"]73 dart 360 - YouTube[/ame] 73 dart '76 360 block .040 over, stock style pistons.. stock crank home ported heads (not extreme) Crane 280 .480/.480 cam Comp 901-16 springs Summit? headers (I can't remember where I got them) 2 1/2 exhaust with universal x-pipe kit and thrush chambered mufflers dumped before the axle.
I just received my Accurate Exhaust System for my 69 Barracuda droptop with a slant 6 from Accurate Exhausts in Oregon. Very happy with it. Talk with Butch or Tom. They also have a FB page and website.
Jeg's 2.5" exhaust system with their generic turbo mufflers. Stock 273 manifolds and headpipes. 5.2L magnum with factory EFI. I think the PCM needs to be flashed- cold start is a little rough.
@goldduster318 how are you liking the exhaust? Quiet enough while driving that you can easily talk or listen to the radio?
my 72 swinger after break in, and before bodywork and paint. .030 over 383 11:1 bowl blended 516s .590 cam street dominator intake with 750 mighty demon open 2" fender well headers. oh....it also had a wiped cam lobe
My old 2.5" exhaust with no X and no H on the newer motor. Had it on the run stand so I figured why not compare the old high compression motor to the new lower compression motor with that same exhaust since I changed it all at once at rebuild. The Cherry Bombs are really rusted out. Notice all the blowout on the concrete lol.
