Post your sound bytes here.
Engine size-440 .030" over 11-1 compression, 850 Holley, TM- intake
Cam size- .590 solid, roller rockers
Header brand and size- Pro Parts 2" primary to 3" collector
Pipe diameter 3" Summit kit
Cross over - X pipe, H pipe, - None
Muffler type and size- Summit 3" kit
Tail pipes, size.- Summit 3" kit
This is the 3" summit exhaust kit for the small block with headman headers modified for my Big Block
[ame="http://www.youtube.com/watch?v=jKpTqy9bKAc"]YouTube- Demon with new 3" exhaust[/ame]
Heres how the 410 sounded before I pulled it.
.040
9.9 comp
4''stroke
solid flat tappet .573 284* 110*cl
LD340 intake
1 5/8 headers
Jegs mandrel bent 2 1/2'' kit w/Jegs mufflers
[ame="http://www.youtube.com/watch?v=XnFpUn3judU"]YouTube- 67 valiant 410cid .mov[/ame]
Heres my 68 hardtop with 340/4spd and FlowMasters with 3" pipes and turndowns.
[ame="http://www.youtube.com/watch?v=sQolotFcSBA&feature=related"]http://www.youtube.com/watch?v=sQolotFcSBA&feature=related[/ame]
Here´s my 73 Dart with 440, Header, 2 1/4" Dynomax Turbo Muffler
[ame="http://www.youtube.com/watch?v=P8SNfldKCyY"]YouTube- MOV04546.MPG[/ame]
Here is my 73 Dart with 440, Header, 2 1/4" Dynomax Turbo Muffler
[ame="http://www.youtube.com/watch?v=SYQavq4uB5k"]YouTube - Dodge Dart[/ame]
Brazilian 1977 Dodge Dart
318 LA
Mopar Performance 284 / 528 solid cam
Ported heads
9.8 /1 comp
Edelbrock Performer RPM Intake
Holley 650 cfm double pumper carb
Short headers
X - pipe
Glasspacks dumped before the rear axle
A bone stock slant six with Electronic ignition and a turbo muffler.
[ame="http://www.youtube.com/watch?v=ecsmdtWMSro"]YouTube - Slant Powered Leaf Blower[/ame]
[ame="http://www.youtube.com/watch?v=saSrWXPVOu0&hd=1"]YouTube - '73 dart swinger w/ thrush mufflers[/ame]
360 w/ cheapo headers, 2 1/2" x-pipe to thrush chambered mufflers.
Hi all ,
Dart Swinger 70'
318ci
Holley2245:)bootysha:)
acc stock
header's summit
line and muffler 2.1/2
[ame="http://www.youtube.com/watch?v=Dr2r3U1Y-f0"]http://www.youtube.com/watch?v=Dr2r3U1Y-f0[/ame]​
340/422ci - 4" stroke Ross Flat top Piston 10.5:1 CR
Headers- TTI340A-C5
Comp Cam XR280R Solid Roller
Comp Pro Mag 1.5 Roller Rockers
AirGap with 750 Quick Fuel and 1" super sucker spacer
Stock Edelbrock Closed Chamber Heads (63cc)
3" TTI exhaust X pipe Dynomax Super Turbo
Timing advanced in this video to Idle at 18*, I have since set total at 34* which Brought idle to 16* a little more loopy idle.
[ame="http://www.youtube.com/watch?v=j6kmWW_o2y0"]YouTube - 422 stroker in 72 Duster 1st run[/ame]
This could be a repost but I found this video on youtube and had to put it on here. I am going to make my Dart sound just like this.
[ame="http://www.youtube.com/watch?v=HDi8pK09sGs"]YouTube - 1969 Dodge GTS 340 Four Barrel[/ame]
Here is my dart with Flowmasters:
[ame="http://www.youtube.com/watch?v=FmJNB22eMVk"]YouTube - 1972 Dodge Dart flowmaster exhaust[/ame]
[ame="http://www.youtube.com/watch?v=yGpsnUniVSU"]TTI 2.5" x-pipe with dynomax ultra-flows[/ame]
Finally got the exhaust all hooked up and leak free. It sure is a far cry from the video about 10 posts up from a year ago!
headers and 2 1/2" mandrel bend pipes to back , dynomax super turbo mufflers. Sure is an improvement over the crushed leaky hooker headers with regular bend pipes .
Mild 440
TTi headers and full 3" exhaust with x-pipe and 40 series mufflers
[ame="http://www.youtube.com/watch?v=Oj2AFrSR2x0"]YouTube - ‪69 Dodge Dart 440 exhaust‬‏[/ame]
[ame="http://www.youtube.com/watch?v=e7l0iJQNMC8"]YouTube - ‪cuda 001‬‏[/ame]
