Hello all,
I'm so close to bringing my Dart to life. I have crank and fuel but no spark. I bought a spark plug test light and verified. I looked for voltage to the coil with key on and it is getting a bit over 6 volts on the positive and 1.5 volts on the neg. I checked the connector going to the distributor and it was the same 1.5 volts. Turning the key brings the positive side of the coil to a bit over 11 volts. I replaced my spark pugs and checked all the connections. My ignition module is also grounded. I'm at a loss.
