famous bob
mopar misfit
How is it you’re at 12.5:1 compression with 91 octane fuel?
HE LOST ME WHEN HE SAIS MORE VACUUM AT WIDE OPEN THROTTLE !
Why are your pistons are installed upside down...?
Edelbrock mod just closed the thread everyone was commenting in. It's unfortunate, but I think that there's enough info out that at this point that people can find it by searching.
I run 11.3 with same head and lessHi. I use aluminum heads and flat pistons paired with cometic 0.051 compressed thickness gasket. Also live at 6500 ft above sea level.
I’ll see them at SEMA..Typical. It’s the first post Peter has closed that I have been involved with but Nate who used to be there deleted, removed threads, removed my replies, and blocked my IP address. Unfortunately when the topics start to point in their direction, they seem to close them with no definitive explanation of the issue. (Most likely they don’t want to mess with “us” after all we aren’t driving Chivvey’s and we’re just chump change to them. My 2 cents. WTF?
I saw them at SEMA in November of 2019. Don’t expect any new information from the guys that show up there.
Bob, well, the edelbrock screen indicates -7 at WOT, Im not sayinf it physically has vaccum, just the ECU sensor reads as such!. Even with the engine off it reads -5.9 or something like that...
Yes, I guess I put them “on the spot” in looking for some definitive info re rotor phasing, pity that this was their response. The whole loose chain tack was just a diversion. At the end of the day they really should welcome that input in an effort to improve their product. Anyway, I’m really pleased with the input provided on this thread, thanks!Typical. It’s the first post Peter has closed that I have been involved with but Nate who used to be there deleted, removed threads, removed my replies, and blocked my IP address. Unfortunately when the topics start to point in their direction, they seem to close them with no definitive explanation of the issue. (Most likely they don’t want to mess with “us” after all we aren’t driving Chivvey’s and we’re just chump change to them. My 2 cents. WTF?
So I drove my car this weekend after installing the MSD adjustable rotor as others have talked about earlier in this thread. Night and day difference. Now I can get my cruising timing back to where it should be. It starts quicker, idles better, and my long and short fuel trims are lower than before. No more breakup above 3K rpm.
Also many have had an off idle stumble so I also replaced the TPS sensor and the off idle stumble is gone. Not sure if part is due to the rotor or not but most likely bad TPS.
This is how it should have run from the beginning.
TPS sensor part # TH-42 if you have the 4150 style. Bad TPS sensors have been talked about lately on the Edelbrock forum. My guess is when they lowered the price to compete a couple years ago cheaper sensors were part of the cost savings. I have also had to replace my O2 sensor.
Hopefully this works. Should have all the numbers you need!
PF4 Easy to find --replacement Part Numbers - Edelbrock Community Forum
super, thanks a lot, very useful.
List is good to have, but use it with some caution. I know for a fact that the rotors listed aren't the ones in the mopar distributor. Not sure if there are any other mistakes, or parts that are mopar specific.
TPS is correct, TH-42 for the 4150 style
So there is a new post on the EFI forum about the timing topic we have been discussing here. I have my opinions about it. What do you guys think?
ProFlo Mopar Distributor Rotor Phasing - Edelbrock Community Forum
Unfortunately the topic is locked so we can’t dispute it over there.
Well, right out of the gate it doesn't appear that it's even a small block mopar. In addition they have the photos marked as CCW rotation, but a small block distributor spins CW.
Multiple users, myself included, have posted photos that contradict what they're showing
Exactly what I was thinking and why I didn’t want to comment until I saw others reactions. Total BS again.
Unfortunately we can’t reply over there as the thread is closed but I may reply in the thread about how to get more timing from SBM.
