yellow rose
Overnight Sensation
You newly weds aren't crusty. more like a pastry or apple turnover. lol
That's true. I'm actually pretty mushy anymore. Straight mush. Oatmeal type mush.
That's what I do....Trust me, I learned along time ago to cover my hind parts so guys can't do me dirty like that. I tell her everything I say on here right up front. That way I'm clean. She's already heard all that. I did that when we started dating. Saved me some really embarrassing stuff. I had friends saving up crap to tell the wife for years but I told her ahead of time.
Actually a very good question. I would be interested in knowing as well. No sarcasm or ribbing intended.J par, a quick question. I believe bolting them on "as is" will net you some horsepower. But just for conversation, if you loose 1 mph and can't get past 12.7's, what would be your next plan? Hypothetical question, I know.
Check the air density calculator..J par, a quick question. I believe bolting them on "as is" will net you some horsepower. But just for conversation, if you loose 1 mph and can't get past 12.7's, what would be your next plan? Hypothetical question, I know.
A test you can do now is pour a little rubbing alcohol (or spray carb cleaner) into the ports and see if the valves hold it. If not, you can lap the valves sometime this winter and have them ready for Spring.
I wasn't planning on just dropping them on when the time came. I'll probably take them up to a shop just for warranty purposes and pay the 50 or $80 to just have them looked at. if they need to do a couple things for another fifty bucks or something I'm not going to get bent out but if they're talkin they need to put a few hundred dollars into them then I'm sending them back.... The paperwork says that they have to be checked out before you use them... Thye do come with a one-year warranty... Not living and dying on that but doing my part..A test you can do now is pour a little rubbing alcohol (or spray carb cleaner) into the ports and see if the valves hold it. If not, you can lap the valves sometime this winter and have them ready for Spring.
I was just thinking of it as a report card on the quality control of SM. IF somebody bolted them on, would the valves have sealed. no biggyI wasn't planning on just dropping them on when the time came. I'll probably take them up to a shop just for warranty purposes and pay the 50 or $80 to just have them looked at. if they need to do a couple things for another fifty bucks or something I'm not going to get bent out but if they're talkin they need to put a few hundred dollars into them then I'm sending them back.... The paperwork says that they have to be checked out before you use them... Thye do come with a one-year warranty... Not living and dying on that but doing my part..
Cream puff ? lol I think j par should bring his snowmobiles over to your place this winter. He could bring his new heads and you and him could check them out and clean them up.That's true. I'm actually pretty mushy anymore. Straight mush. Oatmeal type mush.
Spend some quality bonding time together. lol
Think of it, j par gets stuff done and you need help and ambition. He has both.
I didn't know that, thank you. I seen that Speedmaster sells a stud kit for $84 plus shipping. Of course I'll get all four gasket$ and a bottle of Redline water wetter and some gallon$ of distilled water for the cooling system$.. and 7 quarts of $8 a quart oil and an oil filter.Do you have washers for the head bolts. need washers with aluminum heads.
Yeah when I got them I was pretty jacked up and I still think a lot of I them..Those Blue Direct Connection valve covers got me all wobbly kneed.
I got the Speedmaster head stud kit when I got my heads. Is there any down side to head studs?
Cley
I'll have to look when I get home.
Cley
Cley
One downside I've read about is that there can be issues getting the head on and off the studs on the driver side when the engine is in the car. May not be enough clearance to brake booster or other stuff.
I better get this subject turned around off of snowmobiling (Rose's favorite subject) and back to the heads..
I guess from what I'm gathering I'm going to need new head bolts? Likely ARP. It's what I have now...
The speedmaster head stub kits works fine....have a set torqued down to 110 ft lbs...you can back the studs off to get them out since there is an allen head wrench on the end of them....
