yellow rose
Overnight Sensation
I would buy a good timing chain and forget about all the tricks. Lol.
That’s why I spend for the GD.
Lord help me I have to agree LOL...I would buy a good timing chain and forget about all the tricks. Lol.
You can think of it as Variable Cam Timing... LOL.It seems to me all the trouble of degreeing a cam is lost with a stretched timing chain??..
I talk to Ted about that when the motor was built and he seemed to have no use for it...That’s why I spend for the GD.
no likelihood and I'll probably just go back out to Ted and grab a new timing chain slap it on and be happy for another five years. with all the work I have to do to clean this engine up and get everything else done all I need is another Fiasco.
My bigger concerns are with the cometic head gaskets sealing or not sealing or if I'm going to end up just tossing that stupid 8553 fel pro gasket on there and bich at Summit that they sold them to me for 15 bucks too much because Edelbrock slap their name on them...
I bought the cometic cuz I wanted quality and now they're just becoming a pain in the butt...
way too much overthinking on the simplest things... LOLIt’s kinda funny my junk ran 6.0’s when fresh and after 4 years of racing it still runs 6.0’s. Lol. Timing chains rule.
Your right, some will spend hours getting it to the degree, only to lose a couple? LOL. Forget the degree wheel. Put number 1 cylinder on TDC, and then put a straight edge on the exhaust/intake lifters. They should be bevel, no gap. If there is, then move the cam in the correct direction. Use a decent chain set (edelbrock is decent to me - 75 bucks) and never look back.Lord help me I have to agree LOL...
LOL.... I said how I'd check the cam. The old method used by racers at the track when they tore down engines. get the lifters even and your ready.Did you look at the video I posted? Why even degree the cam? When you never test anything you’ll run anything. What I posted was straight junk. If we could have found a gear drive local the guy that owns it would have gladly bought it. Junk IS junk at any price.
Well, I'm obviously not in support of a loose chain. Neither am I opposed to gear drives. lol. But, a decent chain will survive for years - and proven consistency are in those that bracket race every weekend and the ET doesn't change. Many bracket racers I know run chains, some don't tear their engines down in 3-6 years, and they can dial and run to the hundredth, maybe even thousands of dial in time. Also, the car over the course of that time usually won't slow up - if anything, it will run a couple tenths faster after a 100 runs. Oh, the only way your method of "bouncing 20* under load" works to show chain flop is if the distributor is locked. I'm not trying to educate the educated, but as you say, somebody else might be reading through this thread and I'm just trying to get a perspective out there.....Right...I got what you said. What I said is that where you put it to start? That would be straight up and almost no one does a cam straight up any more (I do most of the time).
Plus, look at your ignition timing with a load on the engine. That mark will move all around. I’ve seen them move 20 degrees. Yeah, that’s great for performance.
Well, I'm obviously not in support of a loose chain. Neither am I opposed to gear drives. lol. But, a decent chain will survive for years - and proven consistency are in those that bracket race every weekend and the ET doesn't change. Many bracket racers I know run chains, some don't tear their engines down in 3-6 years, and they can dial and run to the hundredth, maybe even thousands of dial in time. Also, the car over the course of that time usually won't slow up - if anything, it will run a couple tenths faster after a 100 runs. Oh, the only way your method of "bouncing 20* under load" works to show chain flop is if the distributor is locked. I'm not trying to educate the educated, but as you say, somebody else might be reading through this thread and I'm just trying to get a perspective out there.....![]()
When you build an engine that the valves kiss the piston every stroke, accuracy is a must .LOL
