How thick is that radius plate?
just under 1/2" .410"
It looks much larger in the pic because you looking at my green epoxy floor, and it look like it part of the radius plate
Not my own.Hey Mattax do you have a log with fuel pressure?
All channels using a 5 V reference or supply look noise free.So tell me what you see............................
Heck, You could be doing side work for people!Got my flow bench adapter back and installed on my bench.
Calibrated earlier
No need for these water gauges any more
This is sooooo much simpler. and it will record all the data so you don't have to right it down!
Flow adapter and my favorite Epoxy port 360 head on.
flow number were with in a couple of numbers
Meaning that my old data will be comparable with my new bench and electronic gauges.
Sad part is that i got to play with it for sever hours and verify every thing works.
But now i have to pack it up with all the rest that going to my new house.
Had to get this much done now, because my new house don't have any 220 power in the garage.
BUT MY SHOP WILL!!!!!!
May be a while before that.
It was fun getting to play with it for a while. All i wanted to DO!!! Was get my die grinder out...........because i know exactly were i would grind
Focus focus! Must Clean out the Garage and finish packing the House
Maybe i will make one more run after i clean up the port. Heads have been setting for years. Shhh don't tell wife........maybe she will just think i'm vacuuming out the truck.......................
Best I an figure Innovate Motorsport LM2 uses Molex "Mini-fit" connectors. (Terminals are rated for 9 to 13 amps.)Could be the molex terminals or internal connections.
I was trying to decide how big of a inline fuse to us. And was amazed that the o2 heater only took 3 amps.Best I an figure Innovate Motorsport LM2 uses Molex "Mini-fit" connectors. (Terminals are rated for 9 to 13 amps.)
Housings, terminals, and even premade cables are available from the usual places like Mouser, Digi-key etc
Mini-Fit Family Power Connectors - Molex
Bought it mid 1998.I’d be missing that garage too!!
How long were you living there?
Are you kidding me! With the thousands of dollars he has into his "education" via the yr coaching he's in way too deep... LOL...Based on all the love the Ede/Carter carbs are getting on “that” thread....... sounds like you need to get an eBay special and plop one of those on your motor.
