Junior340
Junior is doing well. Not much different since last post.
This was at work the other day.
This repair didn't last very long. HAHA I tried.View attachment 1715481452 Circuit board repair time.
Just solder, is that where I went wrong?Did you add a small piece of wire across your gaps, or just a solder bridge?
Add a small piece of wire as a jumper. Just a solder tracing is not strong enoughJust solder, is that where I went wrong?
Hi AndyI did add wire to the repair (don't remember doing that). Tested all the circuits, all are good but some of the pins were loose so I carefully swedged them. Devin suggested a ground issue, I bet he is correct. I will check that out next when it isn't a billion degrees out.
Thanks and I did understand that right from your tx. I'm double checking all of that with my power probe as I go before plugging instruments back in.Hi Andy
By saying "grounding issue" I mean something is grounding on that electrical circuit that shouldn't. Wires rubbing through somewhere, bulkhead issues, fuse box issues etc. The circuit board 'ribbon' is probably just the weakest link.
Happy hunting, and please..... no mushroom clouds!!!
41 today here first time this warm in a while and no sun for 15 days and no snow except in hills.Great read on a cold day in Virginia.
Thanks. The quality of the chrome makes the job easier for sure.Center Caps really cleaned up very nice!!!
Thank you . That gives me motivation also. Good looking GT!!!Keep up the posts, you're giving me motivation on my 67 GT!!
Another 340 powered (727 and 8 3/4) Dart GT, my daughter has claimed as hers, so this is her behind the wheel at Woodburn dragstrip in Woodburn, Oregon.
