They aren't slotted on the bottom. They're dedicated to the Carter BBD pattern. Whatever the Carter BBD pattern is, that's what the intake pattern is.Are you insinuating that slotting the holes in the base plate at an angle will not work? I was thinking of how the blp and qft base plates that fit both 4150 and 4500 are. You could humor me with some measurements off of that intake LOL
Right. But this ain't it.They do make an adapter for that Holley 2210/2245 to BBD. Or at least they used to.
There are 2 size BBD's, the larger one looks nothing like the 'teener one, it has the same pattern as the Holley 2210/2245. The bolt pattern is unique to them.Are you insinuating that slotting the holes in the base plate at an angle will not work? I was thinking of how the blp and qft base plates that fit both 4150 and 4500 are. You could humor me with some measurements off of that intake LOL
Cool! How'd it work?Cheap & Nasty, that's how I had to make the adapter when I did it to put a 2245 Holley on My SuperSix intake. I decided to slot the base plate in the 2245 to match the smaller BBD at the throttle end to keep the throttle & kickdown stuff where it belonged, and let the inside end hang over with all-thread studs in the right spot, shifted a bit forward. Only problem is the base material needed filler there, iron & aluminum. The Al intake was 1.5 10ths quicker, for whatever reason, just was.
View attachment 1716324734View attachment 1716324735
Great, but without the right stall converter, I cut the throttle shaft in half....blocked the Pass. shooter, & put a VS Pot on it. Worked much better, after rejetting, it posted the time slips in My 'Glimpse of the Past' thread. I really wish I'd have come up with a proper 904 converter for it back then, but.....Cool! How'd it work?
The Harbor Freight dollies are handy, but a few of mine have been infested with termites. Anyone else have issues with these???So how cheap & nasty is cheap & nasty gonna be? Before I answer that, here's my first mod. See that hole in the middle of the main oil passage plug? It's a little big, ain't it? That's cause it's a beeotch to drill a .040" hole without the bit breaking. So, my solution is to tap it to 1/4 x 32 UNF and screw a Holley .040" main jet into it. Problem solved and the timing chain now has pressurized oil.
Now on to the cheapness.
Here's one of the original 1966 date coded main bearings.
Purdy, ain't it? They all are just that good. So are all of the rod bearings. So yeah, you guessed it. They're goin back in.
Here is cheap & nasty sittin on one of the dollies I made from a Harbor Freight furniture dolly. I got several on sale when they were under 10 bucks each. I reinforced the crap out of all of them with 1 x 4s and came back over those with a piece of 3/4" plywood. I have two more to do. Thanks to @krazykuda for that. Thanks Karl!
Ain't seen that one yet.The Harbor Freight dollies are handy, but a few of mine have been infested with termites. Anyone else have issues with these???
Nope, but it's metalmites I worry about here.....The Harbor Freight dollies are handy, but a few of mine have been infested with termites. Anyone else have issues with these???
Actually, there's none. They were striped green originally. They were in a box when I painted the head. lolnot near enough over spray up on dem sprangs!
what kinda surgical suite you operating out of over there man? don'tcha know when ya paint a motor yer supposed to paint everything? stops the insides from rusting too!Actually, there's none. They were striped green originally. They were in a box when I painted the head. lol
Take care of Yourself Rob, gluc-spike/hypo-gly issues???Sorry yall. I'm havin a bad few health days here so this is gettin postponed till I feel better.
Those things are as old as you, NO probably as old as ME!Got Cheap & Nasty's pistons rung. Remember when I always say to hawk ebay for OLD NOS USA made engine parts? Check out the green and white box of Pacific rings. "For power and speed". LOL
View attachment 1716326255View attachment 1716326254
They are OLD, that's for sure.Those things are as old as you, NO probably as old as ME!
My old neighbor told me they would chain cylinder heads and pull it down the street with the tail gate open and his buddy siting on the tail gate using his feet to push the cylinder head down lol cheap head milling.You don't need a machine shop to clean up that head surface. Use the concrete floor or use the side of a 8-12" grinding wheel. A liberal dose of wd40 will help displace the swarf.
It's not right by today's standards. Or yesterday's for that matter. Back when all we had was rent money and book money (school) we fixed plenty of engines using farmer tricks of days gone by.
