ChrisRomello
Whe I was grinding the paint to weld in the passenger’s side a-pillar, I found more rust that I had to cut out and fix...
You are a welding beast! My eyes are hurting just looking at
I tried to use seam sealer but it does not have a long enough open time to get the cowl clamped down (literally 5mins) the 3M panel bond adhesive has an open time of about 2 hours so that will give me plenty of time to get the cowl in place, clamped down and clean off the access adhesive.When you say the seam sealer didn't work on the cowl, are you talking panel bond adhesive like Fusor or 3M, or just regular old seam sealer? The panel bond adhesive has to have clean, bare metal to bite. You are doing some nice work on that car, so keep it up!
Yes, I plan on blasting it and epoxy primering it after the metal work. I will probably use paint stripper and 80 grit on a da mostly but just blast it in the right spaces. I hate it!Once you get all the rust cut out and repaired, are you going to media blast it then use an epoxy primer on it?
