Dodge72
Odd one out
The leak down test earlier was somewhat inaccurate with a misaligned test. We tested it again with a more accurate one, first dry then with oil: Dry test was around 66%, with oil was not much better at around 62%.
The only thing in the back of the cam is the rear cam plug and the cam does not ride on that at all. The rear thrust face is the front of the block. Stock, there is no forward thrust control. The lifter contact points (and I think the oil pump mesh direction) are what keep the sprocket back against the front of the block.I think I remember reading on slantsix.org that the cam actually uses the rear of the block for rear ward thrust so your block wear in the front may not be an issue.
Here ya go with the info: www.slantsix.org/forum/viewtopic.php?t=24119&highlight=
Just one more thing related to this: the lifter-to-cam contact points are what make the lifters rotate continuously to even out wear (and which also rotates the pushrods). The cam being back with move the lifter contact point forward on the cam lobes. It ought to still rotate the lifters, but I would check that visually after start-up.Yes, I got new lifters. Those will be lubed up good and installed today. I'll keep that in mind to check wear pattern, thanks for the tip.
BTW, with the dots lined up, the 1/6 cylinders are not quite at TDC; they are something like 17 degrees off of TDC.
