rapom65
Here is an electrical mod I hadn't planned on before I started but decided to do since everything was opened up and accessible. I added two relays to the headlight circuits to take the electrical load off the headlight switch (same reason for the ignition relay - power is taken directly off the starter relay distribution stud rather than through the ignition switch). The relay with the purple wires is for the low beams and the relay with the red wires is for the high beams. I spliced them into the wiring harness directly above the relays. To make this a hidden system you could do this right at the high/low switch on the floor board and hide the relays behind the kick panel. I like to see the mechanics of a car and they're way more accessible mounted here. There is room for one more relay to the right of the high beam if I decide to add electric fan(s) for the radiator in the future.
A lot is going on in this pic but what is missing is the heavy power wire which will connect the battery, thru the master disconnect switch, to the starter relay which now becomes the main power distribution point. When the master disconnect switch is thrown it will kill power to everything in the car:
Red Arrow = fusible link protected lead to ignition relay
Lt Blue Arrow = used to be the red power lead to the starter relay via the ammeter and black lead from the altenator. Just about everything in the dash got it's power from the black lead prior to the ammeter. Essentially I rerouted power so it flows backwards from the stock setup. I deleted the ammeter and the black lead from the altenator to the firewall. The red lead from the starter relay is now directly connected to the remainder of the black lead which still powers everything in the dash area. It is protected by the stock fusible link at the firewall connection block. Got it?
Black Arrow = fusible link protected lead to low & high beam relays
