Thanks AJ, that's great intel. Well, since I've been a flooring contractor for 35 years at least there's no shortage of epoxy in my warehouse!
This is my process. I have been putting about a 1/8" chamfer in the bore. Once the shaft is close, I clean & dry the bore with brake kleen. Then wipe the bore with silicone. Sometimes there will be a scrape, or some rust pitting in the bore, and this helps fill those small voids.
Yes, trans would need to be apart to seal it like I described above. You could just clean and seal it as-is, not sure how well it will work.Thanks Dan and 66fs. I'm a bit confused. Does the transmission need to come apart to do this, or can it be done from the outside only? Does the countershaft have to replaced? In the above photos, how does the shaft move from the depressed position to flush with the case?
That's a bummer for sure, good luck.Thanks Dan and 66fs. I'm a bit confused. Does the transmission need to come apart to do this, or can it be done from the outside only? Does the countershaft have to replaced? In the above photos, how does the shaft move from the depressed position to flush with the case?
The countershaft in your trans looks used. Do yourself a favor and replace it with a new one. Get the Countershaft Arbor Tool from Brewers and a brass drift. If you are good, you can take the bolts out of the tailshaft housing and rotate it and drive the old countershaft out while sliding the arbor tool in at the same time. Then do your clean up of the countershaft bore and slide the new countershaft back in, pushing the arbor tool back out the front. As soon as the countershaft starts into the front bore, do as Dan says and clean the bore and apply the silicone. Then drive the countershaft the rest of the way in. It is a press fit. When the silicone has hardened use a single edge razor blade and remove excess silicone flush with the front face of the main housing.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
www.brewersperformance.com
I said this in an early post, get some thin gasket material.
Make a patch slightly larger than the shaft.
A little RTV and sandwich it between the bell and the front of the trans.
It works great on a blowpoof as there is flat surface to sandwich it.
Red line heavy shock oil will get out like nobodies business.
Awesome! Congrats!So...I went ahead with the patch method on the leaking countershaft. I cleaned the area several times starting with acetone and ending with brake clean and compressed air in between applications. I used Permatex for Gear Oil, and cut a patch of .030" gasket paper exactly 1-1/8" diameter, which allows for a 1/8" overlap over the shaft. I applied Permatex to the shaft, pushed it with my thumb, then applied the patch and centered it. I placed a very strong round magnet over the patch and left it cure for 48 hours.
Filled the trans back up with Pennzoil synchromesh manual trans fluid and let it sit for 48 hours to confirm it stopped the leak. I reinstalled the trans to the bellhousing carefully so as to not rotate the trans when close to the bellhousing as it might damage the gasket. The gasket does not interfere with mating the trans to the stock bellhousing. Its been a week now and no leaks. Thank you Hyper_Pak for the suggestion!
View attachment 1716277429View attachment 1716277430View attachment 1716277432
