bkd
No more Scoops
Are they going to cut off the excess pipe on the drive shaft hoop or loop? just looks unfinished to me. Then cap the cut and weld it shut. Love the build though keep up the great Hot Rodding.
Yes he is. This is still in progress pics. He would never let something leave his shop unfinished and not done the right way.Are they going to cut off the excess pipe on the drive shaft hoop or loop? just looks unfinished to me. Then cap the cut and weld it shut. Love the build though keep up the great Hot Rodding.
Chassis engineering stage 2 ladder bar setup with strange single adjustable coiloverswhat 4 link are you running?
You must have been reading my mind denny. Just picked up my new racequip helmet and harnesses yesterday.It will be great to see the car back on the ground with all the new race hardware......loaded for bear.
I'm sure you were advised to wear a helmet whenever you take this out for a spin. A roll bar / roll cage can split an unprotected head open if ever actually used for the safety side all those bars. Some states actually out-law roll bars / roll cages for street use for what they say is that very reason.
What's the significance of the 6" rule? Classes or nhra?Looks killer! How far is the driveshaft loop from the front u-joint? Make sure it's under 6".
Racing at tracks. Most I know dont necessarily inspect that part very close.Yeah, that's an NHRA rule. I'm assuming you'll be racing it at an NHRA track??
Thanks alot man.The badassery of this car is off the meter!
We already talked about it all. ill ship you that rear spare tire well after i pick the car back up.I'm sure your fab guy mentioned a firewall between the interior and (the fuel in) the trunk.
Aluminum is the plan.A simple DYI sheet of aluminum directly under the rear seat back / cardboard trunk divider would work great
Terminator x maxI apologize if you already covered it, are you using the Holley Terminator X this time? I just helped a friend set up with Sniper and I really liked the user interface with the Holly system. I plan to ditch the megasquirt one day and change over to the universal terminator.
