Rubber Pad on 8 3/4 Spring setup?
Suspension, Steering and Chassis
  1. mario03srt
    mario03srt FABO Gold Member FABO Gold Member
    569
    132
    Apr 12, 2015
    Amelia Oh
    Local Time:
    4:03 AM
    Hey Mopar Guys/Gals,
    I'm replacing some bent rear shock studs on my Darts 8 3/4 rear end. The rubber pads are very worn and I want to replace while I'm at it. I looked around a bit to include Mancini and cannot locate and am not sure of the correct nomenclature to do a good search. Can someone please tell me the name of these and if possible where to locate.
    Thanks,
    Marion
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    52,771
    38280
    Jan 18, 2006
    Iowa
    Local Time:
    3:03 AM
    Spring isolators I believe
  3. mario03srt
    569
    132
    Apr 12, 2015
    Amelia Oh
    Local Time:
    4:03 AM
    I'll take a pic and post it. It's a pad sandwhiched in there.
    Thansk.
  4. jonn6464
    jonn6464 1970 Duster
    500
    340
    Mar 29, 2017
    Weatherford, TX
    Local Time:
    3:03 AM
    Do you mean these?
    This is what I just put on my 1970 Firebird. I was also curious about these for my Duster.
    I got the leaf springs from ESPO, so I asked them if they sold some. The response was that
    A bodies did not get them, they are metal on metal.
    • Agree Agree x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      19,185
      7086
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      3:03 AM
      F-bodies got ISO in about 75.... I think.
      I saw a 76 Duster up here a few years ago,(going on 20 lol) that the owner said was all original; it had a complete F-body under carriage including the L-bars, and ISO
    • mario03srt
      569
      132
      Apr 12, 2015
      Amelia Oh
      Local Time:
      4:03 AM
      Guys,
      Thanks. I'll have a pic later. I've got to get to where the car is stashed. I'm not sure of the original car for this rear. I will get some markings if possible.
      Marion
    • Jimacuda
      Jimacuda Well-Known Member
      1,862
      623
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      1:03 AM
      F,M,J and late B bodies were iso mount leafs, 1976 thru 88 anyways.
      Big honkin pieces of steel wrapped around rubber pads with the leaf sandwiched inbetween and clamped to the axle.
      7.25, and 8.25 rears.
    • mario03srt
      569
      132
      Apr 12, 2015
      Amelia Oh
      Local Time:
      4:03 AM
      Guys,
      Here are the pics of my Rear Spring Assy. Jonn the pads on the right in your photo look like the right deal. The pad has a center button that centers through the shock mount. I was planning to replace my shock studs as they are bent by the PO who ran Air Shocks. While it was apart I was considering replacing these pads with a new or a steel block etc, as these look soft and old to me. I'm not sure what factory setup this is or is it cobbled to fit a 73 Dart?
    • mario03srt
      569
      132
      Apr 12, 2015
      Amelia Oh
      Local Time:
      4:03 AM
      Where did you get these? Can you share a link etc?
    • jonn6464
      500
      340
      Mar 29, 2017
      Weatherford, TX
      Local Time:
      3:03 AM
      Here is a link to this product...
      With a HUGE caveat... these are for 1070-81 GM F body cars (Firebird, Camaro). I'm not trying to imply that these will work on a Mopar leaf spring. They might, but I'm not saying that they will. I only included that pic to ask if that is what the OP was talking about.
      In the OP's pics, it looks like there is only a pad on the lower side of the axle, unless I'm seeing it wrong.
      Looking at Jimacuda's pics, these 2 sets might be a possible fit...
      Rear Leaf Spring Pads - Chevrolet Camaro - 3.6113
      3.6112 | Chevrolet Camaro | Multi-Leaf Rear Spring Pads | Energy
      ONCE AGAIN, I AM NOT SAYING THAT THESE WILL WORK WITH A MOPAR LEAF SPRING WITHOUT SOME SORT OF MODIFICATION!!!
    • mario03srt
      569
      132
      Apr 12, 2015
      Amelia Oh
      Local Time:
      4:03 AM
      Fair Enough! Thanks!
    • gliderider06
      gliderider06 Well-Known Member
      1,506
      885
      Oct 21, 2011
      Delaware
      Local Time:
      4:03 AM
      My 73 duster had the isolator mounts on it. I just hacked them off today and welded regular perches on the rear. It has an 8 -1/4 rear in it.
    • Jimacuda
      1,862
      623
      Nov 10, 2006
      Phoenix AZ
      Local Time:
      1:03 AM
      I'm going to go with cobbled to fit, final answer:D
      I've not seen any A bodies with original factory isolators on the leafs.
      I didnt think they were used on any A's, but I sure dont know everything.
      The rubber piece you describe sounds like one half of the F,M,J isolator.
      Not designed to be used uncontained from squishing out wherever it wants when clamped.
      Also it cant do much "isolating" of the axle from the leafs if its only on one side.
      • Like Like x 1
      • moparmarks
        moparmarks zippindippintie FABO Gold Member
        1,211
        591
        Oct 5, 2014
        Western Colorado
        Local Time:
        2:03 AM
        Ya I've never seen them on an A body. I've had several 74-76 A's and don't recall them have those.
      • 4spdragtop
        4spdragtop FABO Gold Member FABO Gold Member
        29,573
        9896
        Aug 28, 2009
        Wasting time here
        Local Time:
        3:03 AM
        Heres pics of orig 69 cuda 8 3/4 "S" leafs. I had them re-arched. Not sure if steel/rubber banding is 100% oem?
        There are plastic shims between the leafs(see first pic) that are original.
        • Agree Agree x 1
        • moparmarks
          1,211
          591
          Oct 5, 2014
          Western Colorado
          Local Time:
          2:03 AM
          Ya you can buy the plastic shims. I got new shims and bands when I built my Dart springs
          • Like Like x 1
          • mario03srt
            569
            132
            Apr 12, 2015
            Amelia Oh
            Local Time:
            4:03 AM
            Sorry but thats not what I'm talking about.
            Thanks though. ;}
            • Like Like x 1
            • MopaR&D
              MopaR&D Nerd Member
              4,202
              1039
              Jan 4, 2008
              Fort Collins, CO
              Local Time:
              2:03 AM
              Just get rid of them, they never came from the factory on A-bodies and do more bad than good. I had a 1988 Chrysler 5th Avenue (M-body) with the full ISO-clamp setup, removed them and put in regular shock plates and it actually handled AND rode better, didn't feel like the rear end was flopping around when going over bumps anymore.
              One of those terrible ideas from the 70s just like transverse torsion bars and super low-compression engines.
